I have a Trim-Slice Value using Ubuntu 11.04. It comes with a Ralink RT5370 802.11n WiFi dongle.
When I plug the dongle in, it does not 'just work'; ifconfig and iwconfig do not show the device, though lsusb does show the device listed:
phrogz@trimslice:~$ lsusb | grep Ralink
Bus 001 Device 004: ID 148f:5370 Ralink Technology, Corp.
I downloaded the link for RT5370 from Ralink's Linux Drivers site, resulting in a file named 2011_0225_RT5370_RT5372_Linux_STA_V2.5.0.1_DPO.tar.bz2. After extracting it, the only README in the file mentions the "RT2870 Wireless Lan Linux Driver"; however, the Makefile at the root of the directory does have these lines:
ifeq ($(CHIPSET),)
CHIPSET = 5370
endif
I edited os/linux/config.mk to have these settings:
# Support Wpa_Supplicant
HAS_WPA_SUPPLICANT=y
# Support Native WpaSupplicant for Network Maganger
HAS_NATIVE_WPA_SUPPLICANT_SUPPORT=y
When I return to the root of the extracted directory and run make, however, it fails:
phrogz@trimslice:~/2011_0225_RT5370_RT5372_Linux_STA_V2.5.0.1_DPO$ sudo make
[sudo] password for phrogz:
make -C tools
make[1]: Entering directory `/home/phrogz/2011_0225_RT5370_RT5372_Linux_STA_V2.5.0.1_DPO/tools'
gcc -g bin2h.c -o bin2h
make[1]: Leaving directory `/home/phrogz/2011_0225_RT5370_RT5372_Linux_STA_V2.5.0.1_DPO/tools'
/home/phrogz/2011_0225_RT5370_RT5372_Linux_STA_V2.5.0.1_DPO/tools/bin2h
cp -f os/linux/Makefile.6 /home/phrogz/2011_0225_RT5370_RT5372_Linux_STA_V2.5.0.1_DPO/os/linux/Makefile
make -C /lib/modules/2.6.38.3-trimslice-1.03/build SUBDIRS=/home/phrogz/2011_0225_RT5370_RT5372_Linux_STA_V2.5.0.1_DPO/os/linux modules
make: *** /lib/modules/2.6.38.3-trimslice-1.03/build: No such file or directory.  Stop.
make: *** [LINUX] Error 2
How can I build the driver for this device?
Phrogz
  • 1,712
I use a Tenda W311M that uses the same chip. Thanks for mentioning the download URL for the driver.
This thread http://ubuntuforums.org/showthread.php?t=1285828 mentions the solution.
I hope it works for you.
El Khan
  • 46
You have to install Linux headers corresponding to you kernel release, to get the build directory mentioned:
apt-get install linux-headers-[version]
You can get the kernel release by typing:
uname -r
Peachy
  • 7,235
  • 40
  • 47
JBV06
  • 111
