23
Error to begin with, can't boot
I had to do a hard reboot of my computer, and when booting up it (initramfs I think) gave an error:
mount: mounting /dev/mapper/ubuntu--vg-root on /root failed: Invalid argument
mount: mounting /dev on /root/dev failed: No such file or directory
mount: mounting /sys on /root/sys failed: No such file or directory
mount: mounting /proc on /root/proc failed: No such file or directory
Target filesystem doesn't have requested /sbin/init.
No init found. Try passing init= bootarg.
Trying to mount from Live-CD
I have very, very important data on it, so instead of trying to fix the boot system (or whatever I should call it), I would just like to mount it and copy the important files to a USB stick.
I have tried several guides without luck. The most straight forward seems to be Mount encrypted volumes from command line?. Here is what I've done:
ubuntu@ubuntu:~$ sudo cryptsetup luksOpen /dev/sda3 myvolume
Enter passphrase for /dev/sda3:
ubuntu@ubuntu:~$ mkdir mountpoint
ubuntu@ubuntu:~$ sudo mount /dev/mapper/myvolume m
mount: unknown filesystem type 'LVM2_member'
ubuntu@ubuntu:~$ sudo mount -t ext4 /dev/mapper/myvolume mountpoint
mount: /dev/mapper/myvolume already mounted or mountpoint busy
The mountpoint folder is not busy, it's an empty folder that I can delete if I want. I believe /dev/mapper/myvolume is not mounted, well since I have not done it, and since the following returns nothing ubuntu@ubuntu:~$ mount -l | grep myvolume.
I don't know what information is relevant for the question. In my struggle I have learned the names of dozens of new commands, and it would be too much text to post the information from all of them. So please tell me what additional information is relevant.
Output of blkid
/dev/loop0: TYPE="squashfs"
/dev/sda1: UUID="04BD-5CB0" TYPE="vfat"
/dev/sda2: UUID="4b4af9b9-1290-431a-bfcb-3b8e24d52c54" TYPE="ext2"
/dev/sda3: UUID="09e172eb-1080-4f68-80fb-1386ac0491b6" TYPE="crypto_LUKS"
/dev/sdb1: UUID="369D-508C" TYPE="vfat"
/dev/mapper/myvolume: UUID="0DkUPe-3S13-zNOA-5wi0-uzPb-CCB8-9m14C1" TYPE="LVM2_member"
/dev/mapper/ubuntu--vg-swap_1: UUID="44b26e6d-cb85-4949-b0e8-9421ab515d03" TYPE="swap"
Complete summary from Ubuntu Boot-Repair
I did not try to restore anything, I only used the tool to print a summary of relevant information. Tool used: https://help.ubuntu.com/community/Boot-Repair
Result: https://www.jottit.com/gvwbu/ (many pages)
Mads Skjern
  • 1,058
  • 13
  • 24
Try this:
You need to Boot into a Live DVD/USB environment and open up a terminal window:
Press Applications --- Accessories--- Terminal
Install required packages using the following commands:
sudo apt-get update
sudo apt-get install lvm2 cryptsetup
Probe required module using the following command:
sudo modprobe dm-crypt
You find out which drive it was with the following command:
sudo fdisk -l
You must mount /dev/sda3 myvolume , You need to use cryptsetup:
sudo cryptsetup luksOpen /dev/sde3 myvolume
Now the device is accessible under /dev/mapper/myvolume
Scan for LVM volumes and choose the right volume group name that you are looking for:
sudo vgscan
Suppose it is system, activate that volume:
sudo vgchange -ay system
To find out your root volume, use the following command:
sudo lvs
Suppose it is root system you can mount it with the following command:
sudo mount /dev/system/root /mnt/
To work in volume use the following commands
sudo mount --bind /dev /mnt/dev
sudo mount --bind /dev/pts /mnt/dev/pts
sudo mount --bind /proc /mnt/proc
sudo mount --bind /sys /mnt/sys
sudo chroot /mnt
kyodake
  • 17,808
You have LVM volumes inside the LUKS container. You should let the sytem know about them.
Run
sudo vgscan
sudo vgchange -a y
and then
mount /dev/mapper/ubuntu--vg-root /mnt/whateveryoulike
solsTiCe
  • 9,515
