Ubuntu tries to be helpful remembering touchpad state between reboots... I hate it!
I mean if i don't enable touchpad before rebooting, after boot i will have physical switch by default enabling touchpad, but software switch will remember the disabled state - so now when i turn the physical switch it toggles both physical and software state (so now i have physical disabled and software enabled).
So basically i can't use mouse if i don't plug in external one and then manually tick checkbox in settings dialog.
In some previous ubuntu version it was possible to decouple hardware touchpad switch with system-stored state, so i could have touchpad alway enabled in system, but disable it physically. But i can't find anything in 16.04.
Also all solutions for this problem i found are from 2014 or older...
Thanks in advance for help
EDIT: xinput output
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ RAPOO RAPOO 2.4G Wireless Device id=16 [slave pointer (2)]
⎜ ↳ ETPS/2 Elantech Touchpad id=13 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ Power Button id=6 [slave keyboard (3)]
↳ Video Bus id=7 [slave keyboard (3)]
↳ Video Bus id=8 [slave keyboard (3)]
↳ Power Button id=9 [slave keyboard (3)]
↳ Sleep Button id=10 [slave keyboard (3)]
↳ BisonCam, NB Pro id=11 [slave keyboard (3)]
↳ AT Translated Set 2 keyboard id=12 [slave keyboard (3)]
↳ MSI WMI hotkeys id=14 [slave keyboard (3)]
↳ RAPOO RAPOO 2.4G Wireless Device id=15 [slave keyboard (3)]
EDIT: xinput list-props 13 output
Device 'ETPS/2 Elantech Touchpad':
Device Enabled (139): 0
Coordinate Transformation Matrix (141): 1.000000, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000, 0.000000, 0.000000, 1.000000
Device Accel Profile (265): 1
Device Accel Constant Deceleration (266): 2.500000
Device Accel Adaptive Deceleration (267): 1.000000
Device Accel Velocity Scaling (268): 12.500000
Synaptics Edges (269): 94, 2262, 66, 1174
Synaptics Finger (270): 1, 1, 0
Synaptics Tap Time (271): 180
Synaptics Tap Move (272): 117
Synaptics Tap Durations (273): 180, 100, 100
Synaptics ClickPad (274): 0
Synaptics Middle Button Timeout (275): 75
Synaptics Two-Finger Pressure (276): 282
Synaptics Two-Finger Width (277): 7
Synaptics Scrolling Distance (278): 53, 53
Synaptics Edge Scrolling (279): 0, 0, 0
Synaptics Two-Finger Scrolling (280): 1, 1
Synaptics Move Speed (281): 1.000000, 1.750000, 0.075131, 0.000000
Synaptics Off (282): 2
Synaptics Locked Drags (283): 0
Synaptics Locked Drags Timeout (284): 5000
Synaptics Tap Action (285): 2, 3, 0, 0, 1, 3, 0
Synaptics Click Action (286): 1, 1, 0
Synaptics Circular Scrolling (287): 0
Synaptics Circular Scrolling Distance (288): 0.100000
Synaptics Circular Scrolling Trigger (289): 0
Synaptics Circular Pad (290): 0
Synaptics Palm Detection (291): 0
Synaptics Palm Dimensions (292): 10, 200
Synaptics Coasting Speed (293): 20.000000, 50.000000
Synaptics Pressure Motion (294): 30, 160
Synaptics Pressure Motion Factor (295): 1.000000, 1.000000
Synaptics Resolution Detect (296): 1
Synaptics Grab Event Device (297): 0
Synaptics Gestures (298): 1
Synaptics Capabilities (299): 1, 0, 1, 1, 1, 1, 1
Synaptics Pad Resolution (300): 31, 31
Synaptics Area (301): 0, 0, 0, 0
Synaptics Noise Cancellation (302): 13, 13
Device Product ID (260): 2, 14
Device Node (261): "/dev/input/event7"
