A few hours ago, I installed Ubuntu 14.04 alongside Windows 7. Everything went fine, installed all my games and programs. But, then I realized that ALT + TAB, CTRL+ALT+T key combinations (as well as many others) do not work.
This is really annoying since I like to use ALT + TAB for multitasking. Anyways, I realized that they were mapped as SHIFT because as you know, if you hold SHIFT and press any key, it will be in CAPS. So that's what happens when I press CTRL or ALT.
It's a custom-built desktop. I'm using a GAMDIAS USB keyboard.
sudo lsusb
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 004: ID 0c45:7603 Microdia
Bus 001 Device 003: ID 1b80:b40c Afatech
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 009 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 008 Device 003: ID 1532:0504 Razer USA, Ltd
Bus 008 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 007 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 006 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
user.dz
  • 49,176
JasonVS 1
  • 75
  1. Install driver from https://github.com/Swoogan/aziokbd
     sudo apt-get install mercurial build-essential linux-headers-generic dkms
     hg clone https://bitbucket.org/Swoogan/aziokbd
     cd aziokbd
     sudo ./install.sh dkms
  2. Add kernel option to grub to prevent usbhid from being used for this keyboard. Append:
     usbhid.quirks=0x0c45:0x7603:0x4
    to GRUB_CMDLINE_LINUX_DEFAULT in /etc/default/grub.
    Example:
     GRUB_CMDLINE_LINUX_DEFAULT="quiet splash usbhid.quirks=0x0c45:0x7603:0x4"
  3. Update grub
     sudo update-grub
  4. Reboot
References:
user.dz
  • 49,176
