I bought a keyboard that is shown on lsusb:
Bus 002 Device 009: ID 0c45:7603 Microdia
but the Ctrl, Windows/Super and Alt buttons are all mapped to Shift button. So I followed the hardware code and find this solution here, which works fine:
dkms status aziokbd
aziokbd, 1.0.0, 3.13.0-48-generic, x86_64: installed
However, after reboot, the keyboard goes back to original state( ctrl/alt/win mapped to shift) while dkms status is same as above, so I have to sudo dkms uninstall -m aziokbd -v 1.0.0 and install again.
How could I "save" the installed state? thank you.
I've ubuntu 14.04. Output of uname -a
Linux PC 3.13.0-48-generic #80-Ubuntu SMP Thu Mar 12 11:16:15 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
  • debug info after installed, rebooted and not working:
    dkms status
    8192cu, 1.9, 3.11.0-26-generic, x86_64: installed
    8192cu, 1.9, 3.13.0-44-generic, x86_64: installed
    8192cu, 1.9, 3.13.0-45-generic, x86_64: installed
    8192cu, 1.9, 3.13.0-46-generic, x86_64: installed
    8192cu, 1.9, 3.13.0-48-generic, x86_64: installed
    8192cu, 1.9, 3.2.0-65-generic, x86_64: installed
    8192cu, 1.9, 3.2.0-67-generic, x86_64: installed
    8192cu, 1.9, 3.2.0-68-generic, x86_64: installed
    8192cu, 1.9, 3.2.0-69-generic, x86_64: installed
    8192cu, 1.9, 3.2.0-70-generic, x86_64: installed
    8192cu, 1.9, 3.2.0-72-generic, x86_64: installed
    8192cu, 1.9, 3.2.0-74-generic, x86_64: installed
    virtualbox, 4.3.10, 3.13.0-46-generic, x86_64: installed
    virtualbox, 4.3.10, 3.13.0-48-generic, x86_64: installed
    virtualbox-guest, 4.3.10, 3.13.0-46-generic, x86_64: installed
    virtualbox-guest, 4.3.10, 3.13.0-48-generic, x86_64: installed
    #########################################3
    lsmod | grep -e usbhid -e aziokbd
    aziokbd                12900  0
    usbhid                 52659  0
    hid                   106148  2 hid_generic,usbhid
    lsusb -t
    /:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/2p, 480M
        |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/6p, 480M
            |__ Port 1: Dev 3, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
            |__ Port 1: Dev 3, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
            |__ Port 2: Dev 4, If 0, Class=Human Interface Device, Driver=usbhid, 12M
            |__ Port 3: Dev 5, If 0, Class=Video, Driver=uvcvideo, 480M
            |__ Port 3: Dev 5, If 1, Class=Video, Driver=uvcvideo, 480M
    /:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/2p, 480M
            |__ Port 2: Dev 3, If 0, Class=Vendor Specific Class, Driver=rtl8192cu, 480M
  • debug info after reinstalled and working:
    dkms status
    usbhid                 52659  0
    aziokbd                12900  0
    lsusb -t
            |__ Port 1: Dev 7, If 0, Class=Human Interface Device, Driver=aziokbd, 1.5M
            |__ Port 1: Dev 7, If 1, Class=Human Interface Device, Driver=aziokbd, 1.5M
user.dz
  • 49,176
The usbhid still loaded as driver for the keyboard. It seems quirks didn't work as modprobe option.
  1. Try kernel option from grub, add:
    usbhid.quirks=0x0c45:0x7603:0x4
    to GRUB_CMDLINE_LINUX_DEFAULT in /etc/default/grub
  2. Update grub
    sudo update-grub
Reference: Prevent usbhid from claiming USB device
user.dz
  • 49,176
