14
I just discovered that Oracle's (Sun's) Java6 has vanished from the Canonical's partner repository.
Before Java was taken from all repositories I had purchased Minecraft for play in Ubuntu. After recent re-install I can not find a way to play this game in the only OS installed now on my systems.
Open source Java equivalents will not run this piece of software nor am I able to use Yahoo Games with my friends. Somewhere I should have been given a choice as to what security risks I'm willing to deal with in order continue to use or not use paid commercial software.
Is there any solution besides directly downloading the java from sun and trying to re-install manually? This method coupled with my short Ubuntu term skills is not an option.
Flyk
  • 1,480
  • 18
  • 24
5 Answers5
17
Sun Java has been disabled via a security update due to it exposing users to known security holes and has been removed from the partner archive.
Due to the severity of the security risk, Canonical is immediately releasing a security update for the Sun JDK browser plugin which will disable the plugin on all machines. This will mitigate users' risk from malicious websites exploiting the vulnerable version of the Sun JDK.
As such people are strongly encouraged to either install OpenJDK or Oracle's JDK for their Java needs. Third party PPAs that distribute "sun java" earlier than update 28 are also vulnerable, and should not be recommended for any kind of use.
This page has a more detailed explanation of the issue:
And you can find information about Java in the official documentation:
To install OpenJDK follow these instructions:
and here are instructions from this site if you want to install Oracle Java:
Jorge Castro
  • 73,717
1) Oracle JDK will not longer be released or supported with Oneiric, OpenJDK will be used instead. You will ofc still be able to manually install it and use it free of charge by downloading it from the Oracle download page.
2) Icedtea will still be used for integration on 11.10 as you can see here.
Bruno Pereira
  • 74,715
You can still install Oracle (Sun) Java JRE manually, by applying this easy how-to: http://sites.google.com/site/easylinuxtipsproject/java
That way, you don't run risks with unverified PPA's and such.
Pjotr123
  • 580
According to Oracle, OpenJDK is now the official version of Java. http://blogs.oracle.com/henrik/entry/moving_to_openjdk_as_the
To install in Ubuntu, just type in:
sudo apt-get install openjdk-7-jdk
That'll get everything working for you without problems. Enjoy.
Geekoid
I managed to install Sun Java in 11.10 by using partner repository from 11.04:
sudo add-apt-repository "deb http://archive.canonical.com/ natty partner"
sudo apt-get update
sudo apt-get install sun-java6-plugin
It works fine in FireFox and Opera. The version is Java 6 update 26. On http://java.com there is a newer version -- update 27.
Edit: Since then I am using an excellent shell script, which automates retrieval and installation of the Oracle (Sun) Java Runtime Environment. It is provided by Duinsoft as a package update-sun-jre:
Updater/installer for Oracle's (Sun) Java Runtime Environment This package will download the Oracle Java Runtime Environment (JRE), which includes the plugin that enables applets written to the Java Platform specification to be run in Mozilla and other web browsers.
WARNING: Installing this package causes the Java Runtime Environment to be downloaded from http://www.java.com and implies you have read and accepted the Oracle Binary Code License Agreement for the Java SE Platform Products and JavaFX from http://www.oracle.com/technetwork/java/javase/terms/license/.
All the required info and instructions can be found on Duinsoft site.
gadamiak
  • 207
