I download the latest Aptana 3.0.5 after reinstalling ubuntu 11.10.
I place aptana in the /opt/ folder. Upon trying to launch the application it warns me with:
A Java Runtime Environment (JRE) or Java Development Kit (JDK) must be available in order to run AptanaStudio3. No Java virtual machine was found after searching the following locations: /opt/AptanaStudio3/jre/bin/java java in your current PATH
Is this error occurring because i'm missing Java packages? Previously in 11.04 i had to install a couple different java packages (i forgot which) and it suddenly worked.
What do i need to do to get aptana working?
Jorge Castro
  • 73,717
According to the getting started guide for Aptana Studio 3:
Prerequisites:
Before you install the Release, you should have the following tools installed and working correctly:
  • Sun/Oracle Java 1.5.x or later on Mac and Linux. OpenJDK is not yet supported.
So using OpenJDK to run Aptana is not officially supported.
Personally, when I had used OpenJDK in the past to run Aptana, I had various issues with it. So I don't recommend it.
I would recommend to install the latest Java 6.x to run Aptana. I can't find any info on how well 7.x is supported, but I don't think it would be as well supported as 6.x at the moment.
Problem is that Sun/Oracle Java 1.6 is not available any more in the Ubuntu partner repository for Ubuntu 11.10, like it was for previous releases. The alternatives that I have seen being suggested for installing Java 6.x are:
alefteris
  • 291
Use this command to open Aptana using openjdk instead of sun's jre AptanaStudio -vm /usr/lib/jvm/java-6-openjdk/bin.
Openjdk is the default jdk in Ubuntu. As an option you are able to install Oracle's jdk if you download it from Oracle's website.
Bruno Pereira
  • 74,715
