When Trying to connect to any device through the Device Search it always ends up empty, even when I have my phone, tablet and Bose SoundLink Mini bluetooth turned on at the same time.
I've tried to find my laptop through my phone, and my phone doesn't even find my laptop. (Visibility is on)
I found this: Ubuntu doesn't detect my Bluetooth receiver, how to fix it?
So here are my outputs of everything:
jeggy@jeggy-Lenovo-Z50-70:~$ bluetoothd -d -n
bluetoothd[3805]: Bluetooth daemon 4.101
bluetoothd[3805]: src/main.c:parse_config() parsing main.conf
bluetoothd[3805]: src/main.c:parse_config() Key file does not have key 'DiscoverableTimeout' in group 'General'
bluetoothd[3805]: src/main.c:parse_config() pairto=0
bluetoothd[3805]: src/main.c:parse_config() pageto=8192
bluetoothd[3805]: src/main.c:parse_config() auto_to=60
bluetoothd[3805]: src/main.c:parse_config() name=%h-%d
bluetoothd[3805]: src/main.c:parse_config() class=0x000100
bluetoothd[3805]: src/main.c:parse_config() Key file does not have key 'DeviceID' in group 'General'
D-Bus setup failed: Connection ":1.88" is not allowed to own the service "org.bluez" due to security policies in the configuration file
bluetoothd[3805]: Unable to get on D-Bus
jeggy@jeggy-Lenovo-Z50-70:~$ start bluetooth
start: Unknown job: bluetooth
jeggy@jeggy-Lenovo-Z50-70:~$ cat /var/log/dmesg
(Nothing has been logged yet.)
jeggy@jeggy-Lenovo-Z50-70:~$ hcitool dev
Devices:
    hci0    38:B1:DB:C6:D9:4A
cat /etc/dbus-1/system.d/bluetooth.conf: http://paste.ubuntu.com/11815776/
jeggy@jeggy-Lenovo-Z50-70:~$ ps aux| grep bluetooth
jeggy     1566  0.0  0.0 265436  6284 ?        Ssl  15:16   0:00 /usr/lib/x86_64-linux-gnu/indicator-bluetooth/indicator-bluetooth-service
jeggy     2715  0.1  1.1 1027824 96216 ?       Sl   15:23   0:01 unity-control-center bluetooth
root      3402  0.0  0.0  19564  3840 ?        Ss   15:33   0:00 /usr/sbin/bluetoothd -n
jeggy     3957  0.0  0.0  15164  2476 pts/7    S+   15:41   0:00 grep --color=auto bluetooth
jeggy@jeggy-Lenovo-Z50-70:~$ lspci | grep Net; lsusb
02:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8723BE PCIe Wireless Network Adapter
Bus 003 Device 002: ID 8087:8000 Intel Corp.
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 005: ID 0bda:b728 Realtek Semiconductor Corp.
Bus 001 Device 004: ID 5986:0249 Acer, Inc
Bus 001 Device 003: ID 0bda:0129 Realtek Semiconductor Corp. RTS5129 Card Reader Controller
Bus 001 Device 002: ID 046d:c52b Logitech, Inc. Unifying Receiver
Jeggy
  • 3,122
  • 16
  • 57
  • 80
You can install a bluetooth driver this way
sudo add-apt-repository ppa:hanipouspilot/rtlwifi
sudo apt-get update
sudo apt-get install rtl8723au-bt-dkms rtlwifi-new-dkms linux-firmware
and reboot.
But if you previously installed Realtek wireless drivers from another source, you need to uninstall them first.
Pilot6
  • 92,041
