I want to execute a script on headphones disconnect but I resent the idea of constant polling of the status when there is already some code executed when it's changed.
In most systems if not all, ACPI can handle this event. To test that:
- Run
acpi_listen Unplug & replug headphones, example output: (mic/ears share in same jack on my laptop)
jack/headphone HEADPHONE unplug jack/microphone MICROPHONE unplug jack/headphone HEADPHONE plug jack/microphone MICROPHONE plugPut
your-script.shin/etc/acpi/Add an event trigger file for your script in
/etc/acpi/events/event=jack/headphone HEADPHONE unplug action=/etc/acpi/your-script.shCheck the other files there to learn from.
You may need to restart
acpidservice to reload changed rules in/etc/acpi/events/sudo service acpid restart
Reference: man acpid
- 49,176
The current version of your script now contains a sleep 0.25 command.
sleep is timer-based so doesn't use any processing cycles while sleeping…
It does use a very tiny bit of CPU to set up the timer, but sleep 1 (sleep 1 second), sleep 60 (sleep for a minute) and sleep 86400 (sleep for a day) all use the same number CPU cycles.
Using ACPI however is the perfect solution as ACPI is event-driven instead of polling-driven.
