Using Xubuntu 18.04, I have a headset that I connect, with its own microphone input. Every time I connect it, I then have to launch pavucontrol, click to the "Input Devices" tab, then select the "Headset Microphone" (instead of "Internal Microphone") in the "Port" drop down menu.
Whenever I disconnect the headset, the "Port" gets switched back to "Internal Microphone", so I have to repeat the process the next time I connect the headset.
Is there a way to do this automatically, or with minimal effort on my part?
I searched online and saw the advice to ensure the PulseAudio module-switch-on-connect is loaded, but I checked pactl list short modules and it appears to be already loaded.
Goh
  • 183
I almost fix it on my laptop running Debian 10 this way:
  1. Unplug your headset.
  2. Edit /etc/pulse/daemon.conf — set log-level = debug
  3. Restart pulseaudio: pulseaudio -k
  4. Run journalctl --follow in a separate terminal/tmux window
  5. Plug in your headset and watch what happens. module-alsa-card.c: Jack 'Headphone Mic Jack' is now plugged in says which jack is detected
  6. Edit /usr/share/pulseaudio/alsa-mixer/paths/analog-input-headset-mic.conf, find the [Jack Headphone Mic] section and change state.plugged from unknown to yes
I said "almost", because
  1. Mic gain did not restore
  2. It does not distinguish external loudspeakers (TRS jack) and headset (TRRS jack) and switch input source anyway, so I get static noise instead of internal mic audio.
The blog post guided me this direction.
Tns
  • 156
The solution sent above works for some PCs, but not for all. I tested solutions for a long time that I could find in the documentation or on forums and this was the only one that worked.
So here is a script that I created that you can add when starting a session (unfortunately not for the entire computer because PulseAudio is a service that runs independently for each user).
#!/bin/bash
index=$(pacmd list-sources | egrep 'index|ports|analog-input-headset-mic' | egrep '\*\sindex:\s+[0-9]'  | cut -d':' -f2);
acpi_listen | while IFS= read -r line; do if [ "$line" = "jack/headphone HEADPHONE plug" ] then pacmd set-source-port $index analog-input-headset-mic; elif [ "$line" = "jack/headphone HEADPHONE unplug" ] then pacmd set-source-port $index analog-input-internal-mic; fi done
This topic is part of my sources and here is another link that helped me in my research and to develop my script:
