17
I get sound just fine using Chrome (e.g. YouTube) or with Rhythmbox playing an MP3.
However, VLC, Xine, and the default Ubuntu "Videos" make no sound, whether with MP4, FLV, or MP3. How do I fix this?
Ubuntu 14.10 Lenono M30-70
Joshua Fox
  • 3,011
16 Answers16
In VLC, in Audio settings, I chose Reverse Stereo, and suddenly I got sound back!
Following that: Left, Right, and even regular Stereo now work.
Joshua Fox
  • 3,011
On VLC > Right Click > Audio > Audio Devices > I had 2 devices HDMI Audio and Built in Analog Audio. Selected one was the HDMI Audio. I changed it to Analog Audio and both the players were fixed after that change.
noelyahan
  • 181
Audio might be muted. In VLC, right-click on the VLC screen, in the context menu select Audio and see if Mute is checked.
Jens Erat
  • 5,131
  • 33
  • 37
As others have mention this is likely a restricted extras issue. The easiest way to install them is to open a terminal and type:
sudo apt-get install ubuntu-restricted-extras
You will need to select 'Ok' for the Microsoft EULA: just tab down until it's selected and press the Enter key.
Same ditto problem was with me and I got it resolved in this way
Audio Settings -> Audio Device -> Changed it and switched back
Cheers!
Same thing happened to me with VLC and Totem in Ubuntu 16.04. However in some other players like mpv sound was working fine.
I had the feeling it had something to do with last time I opened VLC. I was watching a movie on the TV (by HDMI connection) so back then I configured the audio to be played by HDMI output. I powered off the laptop without reverting the configuration.
But now I was not connected to HDMI and in sound configuration only internal speakers were showing.
In the end, the configuration option to blame was to be found in VLC itself. While playing, Audio > Audio device > (select your internal speakers). I seems it did not revert itself to internal speakers, because HDMI output was still selected. Now even Totem is working.
I hope this experience helps someone!
jorgemc
  • 61
First open any video Then Go to Settings --> Sound ---> Applications and increase the sound of your application (if lowered)
According to help.ubuntu::
No sound If you don't hear any sound, try: (a) click System -> Preferences -> Sounds. Then click a sound in the bottom list, and make sure that it's not already selected. You should hear the sound you selected. If not, make sure your speakers are working and that your volume is up. Try clicking another sound in the list, after ajusting your volume. Also make sure your speakers are working. Once you're done, select the sound it was on before and click OK. (b) downloading VLC Media Player by clicking Applications -> Ubuntu Software Centre or Applications -> Add/Remove Appications. Search for "VLC Media Player" and download the program with the orange cone icon. If you don't see an orange cone, the icon might be a cardboard box with all kinds of stuff sticking out of it. In that case, look at the discriptions. Install VLC and then use it to play your movie or DVD.
If this doesn't work, just try to install media codes.
aGer
  • 201
If you changed manually once the output in your sound settings (for me that was an HDMI audio controller to have the sound of my home cinema), disconnecting the HDMI cable and trying to hear back your built in audio card does not work. I had to connect back to the HDMI cable, change manually the output to my built in audio and then it worked.
user604414
Open nautillus. Open your home folder. Press Ctrl+H. Open the .config folder. Delete the vlc folder. Audio goes back to normal.
Julia
Sound Settings -> Applications -> See If 'Videos' Is Muted
I'm running Debian jessie and had the exact same problem as original poster, Audacious & web browsers played audio, but VLC and GNOME Mplayer were muted. I had previously made a change to VLC preferences to capture stills from video. As far as I know, the only changes were the path and frame rate for the scene filter, plus enabled the scene video filter. When I tried to watch a movie with GNOME Mplayer, audio was muted. Audacious played the audio of the exact same mp4 no problem. I disabled the scene video filter and checked all the audio settings (default) in VLC. Still VLC and GNOME Mplayer did not have audio.
Since I usually run just the defaults in VLC, I clicked reset preferences, and I now have audio.
Stephen Rauch
  • 1,156
  • 15
Go to video that you downloaded and then open one video with VLC. Then click audio, in the audio section there is muted, click it.
This worked for me.
Eliah Kagan
  • 119,640
If you changed your pulseaudio settings for a high resolution sound card you need to make sure the default rate is a multiple of 44.1kHz but also lower than 192kHz.
These settings work:
# From /etc/pulse/daemon.conf
default-sample-format = s32le
default-sample-rate = 176400
alternate-sample-rate = 192000
edc83
All my MP4s were "muted" for no apparent reason.
I found that I had previously configured the sound to go to the HDMI port, but this time HDMI was not attached. So I just used the "Settings" control panel, "Sound" section to re-select "built-in speakers".
Dan H
  • 143
u just need to connect the HDMI to an external input and go to settings>sound>output and choose the HDMI output then remove the HDMI cable and back again to the built in source it's just a bug
