46
How to install all possible media codecs from console?
Is there a way to load and save them for some cases without Internet connection?
Thanks in Advance!
Jorge Castro
  • 73,717
UPDATE: 2017-Jan
For Ubuntu 16.04 LTS and 16.10 (12.04 or later)
update the repos:
sudo apt-get update
install CURL tool
sudo apt-get install curl
load VideoLAN repository
curl https://download.videolan.org/pub/debian/videolan-apt.asc | sudo apt-key add -
echo "deb https://download.videolan.org/pub/debian/stable ./" | sudo tee /etc/apt/sources.list.d/libdvdcss.list
sudo apt-get update
install VLC and Mplayer, and their support elements
sudo apt-get install vlc vlc-data browser-plugin-vlc mplayer2
If still using 14.04 LTS (or earlier), then:
sudo apt-get install vlc-plugin-pulse
install remaining Ubuntu 'restricted extras' (146 MB when installed, skip if space is critical)
sudo apt-get install ubuntu-restricted-extras
If you are NOT already using 16.04 LTS (or later), force (manually) install the three key elements for full DVD support:
sudo apt-get install libdvdcss2 libdvdnav4 libdvdread4
Nacht
  • 496
  • 15
david6
  • 14,528
  • 38
  • 46
Yep, I had this problem when I switched to Ubuntu a year ago lol. I only know how to install them. I then made a mirror of my Linux installation as it's a bit more complex than using just the Ubuntu Desktop. I use a Server Thin Client Environment.
Anyway the command to install codecs you need is
sudo apt-get install gstreamer0.10-ffmpeg gstreamer0.10-plugins-ugly gstreamer0.10-plugins-bad gstreamer0.10-bad-multiverse
You may want to check if there is a later version of gstreamer available. The last one worked well for me and all my videos played so I stuck to this version (0.10)
I'm sure there is a way to save it too but hopefully someone will answer your the second part of your question here
To install all the *default media codecs for Ubuntu, run this command in the **terminal:
You will then be asked for your password (your password will NOT show up in the terminal, but I promise you it is there)
Press [Enter]
When prompted, press [Enter] (again)
Once the process is complete, you're good to go!
*Generally you have a choice to download and install them during initial instillation, but you can always install them this way as well after the fact
**To open the terminal, right click on any empty workspace, and select "Open Terminal"
Install the ubuntu-restricted-extras for most of the codecs. To install it, click on the below image: Install via the software center
Install and run aptoncd Install aptoncd to backup all the packages you have downloaded; you can reuse them using aptoncd in any computer.
