I ran:
sudo add-apt-repository ppa:kubuntu-ppa/backports
sudo apt-get update
sudo apt-get install kubuntu-desktop
and after it gave me this error message:
dpkg: error processing archive /var/cache/apt/archives/kde-config-telepathy-accounts_15.04.1-0ubuntu1~ubuntu15.04~ppa1_i386.deb (--unpack):
 trying to overwrite '/usr/share/accounts/services/google-im.service', which is also in package account-plugin-google 0.12+15.04.20150415.1-0ubuntu2
and whenever I try to install a new program or run the suggested solution to this problem, which was mentioned after I tried to install another program, sudo apt-get -f install I get the same error message again.
EDIT: Requested outputs.
sudo apt-get --configure -a
gives this (too large to fit in the question).
sudo apt-get install -f
gives:
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following extra packages will be installed:
The following NEW packages will be installed
0 to upgrade, 1 to newly install, 0 to remove and 23 not to upgrade.
2 not fully installed or removed.
Need to get 0 B/131 kB of archives.
After this operation, 697 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
(Reading database ... 1088636 files and directories currently installed.)
Preparing to unpack .../kde-config-telepathy-accounts_15.04.1-0ubuntu1~ubuntu15.04~ppa1_i386.deb ...
Unpacking kde-config-telepathy-accounts (15.04.1-0ubuntu1~ubuntu15.04~ppa1) ...
while running:
cat /etc/apt/sources.list
gives:
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
deb http://au.archive.ubuntu.com/ubuntu/ vivid main restricted
deb-src http://au.archive.ubuntu.com/ubuntu/ vivid main restricted
Major bug fix updates produced after the final release of the
distribution.
deb http://au.archive.ubuntu.com/ubuntu/ vivid-updates main restricted deb-src http://au.archive.ubuntu.com/ubuntu/ vivid-updates main restricted
N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
team. Also, please note that software in universe WILL NOT receive any
review or updates from the Ubuntu security team.
deb http://au.archive.ubuntu.com/ubuntu/ vivid universe deb-src http://au.archive.ubuntu.com/ubuntu/ vivid universe deb http://au.archive.ubuntu.com/ubuntu/ vivid-updates universe deb-src http://au.archive.ubuntu.com/ubuntu/ vivid-updates universe
team, and may not be under a free licence. Please satisfy yourself as to
your rights to use the software. Also, please note that software in
multiverse WILL NOT receive any review or updates from the Ubuntu
security team.
deb http://au.archive.ubuntu.com/ubuntu/ vivid multiverse deb-src http://au.archive.ubuntu.com/ubuntu/ vivid multiverse deb http://au.archive.ubuntu.com/ubuntu/ vivid-updates multiverse deb-src http://au.archive.ubuntu.com/ubuntu/ vivid-updates multiverse
N.B. software from this repository may not have been tested as
extensively as that contained in the main release, although it includes
newer versions of some applications which may provide useful features.
Also, please note that software in backports WILL NOT receive any review
deb http://au.archive.ubuntu.com/ubuntu/ vivid-backports main restricted universe multiverse deb-src http://au.archive.ubuntu.com/ubuntu/ vivid-backports main restricted universe multiverse
deb http://security.ubuntu.com/ubuntu vivid-security main restricted deb-src http://security.ubuntu.com/ubuntu vivid-security main restricted deb http://security.ubuntu.com/ubuntu vivid-security universe deb-src http://security.ubuntu.com/ubuntu vivid-security universe deb http://security.ubuntu.com/ubuntu vivid-security multiverse deb-src http://security.ubuntu.com/ubuntu vivid-security multiverse
Uncomment the following two lines to add software from Canonical's
'partner' repository.
This software is not part of Ubuntu, but is offered by Canonical and the
respective vendors as a service to Ubuntu users.
deb http://archive.canonical.com/ubuntu trusty partner
deb-src http://archive.canonical.com/ubuntu trusty partner
deb http://download.virtualbox.org/virtualbox/debian vivid contrib
Josh Pinto
  • 8,089
That is the problem:
Therefore two command in a terminal:
sudo apt-get purge account-plugin-google
A.B.
  • 92,125
I saw the attached link.
I think you need to do:-
sudo apt-get remove --purge kde-telepathy-minimal
Also, try to remove orphaned packages using apt-get autoremove
EDIT: If that didn't work, try installing Aptitude:
Install aptitude:
sudo apt-get aptitude
Run it:
sudo aptitude purge kde-telepathy
sudo aptitude purge kde-telepathy-minimal
