I've got an old Dell E1405 which smoothly runs 14.04, with one caveat that is.
When I press the Fn button with arrow-up or arrow-down, the brightness jumps in huge steps.
Is there a way to disable this? So that the brightness is only adjusted by the hardware (I would believe that the BIOS adjusts it because prior to system startup, I can also change brightness)
Any help would be appreciated.
Thank you.
naryfa
  • 93
It may help to set acpi OS and vendor in the bootloader by editing grub.cfg, as mentioned here, by adding this:
acpi_osi=Linux acpi_backlight=vendor
To the GRUB_CMDLINE_LINUX_DEFAULT line in /etc/default/grub. You then need to run sudo update-grub and reboot to make the changes.
This I find works on a few machines, to get brightness to be less jumpy etc
Wilf
  • 30,732
