First thing to note is that there's couple of ways depending on your purpose and shell, therefore this requires slight understanding of multiple aspects. Additionally, certain commands such as time and strace write output to stderr by default, and may or may not provide a method of redirection specific to that command
Basic theory behind redirection is that a process spawned by shell (assuming it is an external command and not shell built-in) is created via fork() and execve() syscalls, and before that happens another syscall dup2() performs necessary redirects before execve() happens. In that sense, redirections are inherited from the parent shell. The m&>n and m>n.txt inform the shell on how to perform open() and dup2() syscall (see also How input redirection works, What is the difference between redirection and pipe, and What does & exactly mean in output redirection )
Shell redirections
Most typical, is via 2> in Bourne-like shells, such as dash (which is symlinked to /bin/sh) and bash; first is the default and POSIX-compliant shell and the other is what most users use for interactive session. They differ in syntax and features, but luckily for us error stream redirection works the same (except the &> non standard one). In case of csh and its derivatives, the stderr redirection doesn't quite work there.
Let's come back to 2> part. Two key things to notice: > means redirection operator, where we open a file and 2 integer stands for stderr file descriptor; in fact this is exactly how POSIX standard for shell language defines redirection in section 2.7:
[n]redir-op word
For simple > redirection, the 1 integer is implied for stdout, i.e. echo Hello World > /dev/null is just the same as echo Hello World 1>/dev/null. Note, that the integer or redirection operator cannot be quoted, otherwise shell doesn't recognize them as such, and instead treats as literal string of text. As for spacing, it's important that integer is right next to redirection operator, but file can either be next to redirection operator or not, i.e. command 2>/dev/null and command 2> /dev/null will work just fine.
The somewhat simplified syntax for typical command in shell would be
command [arg1] [arg2] 2> /dev/null
The trick here is that redirection can appear anywhere. That is both 2> command [arg1] and command 2> [arg1] are valid. Note that for bash shell, there there exists &> way to redirect both stdout and stderr streams at the same time, but again - it's bash specific and if you're striving for portability of scripts, it may not work. See also Ubuntu Wiki and What is the difference between &> and 2>&1.
Note: The > redirection operator truncates a file and overwrites it, if the file exists. The 2>> may be used for appending stderr to file.
If you may notice, > is meant for one single command. For scripts, we can redirect stderr stream of the whole script from outside as in myscript.sh 2> /dev/null or we can make use of exec built-in. The exec built-in has the power to rewire the stream for the whole shell session, so to speak, whether interactively or via script. Something like
#!/bin/sh
exec 2> ./my_log_file.txt
stat /etc/non_existing_file
In this example, the log file should show stat: cannot stat '/etc/non_existing_file': No such file or directory.
Yet another way is via functions. As kopciuszek noted in his answer, we can write function declaration with already attached redirection, that is
some_function(){
command1
command2
} 2> my_log_file.txt
Commands writing to stderr exclusively
Commands such as time and strace write their output to stderr by default. In case of time command, the only viable alternative is to redirect output of whole command , that is
time echo foo 2>&1 > file.txt
alternatively, synchronous list or subshell could be redirected if you want to separate the output ( as shown in related post ):
{ time sleep 1 2> sleep.stderr ; } 2> time.txt
Other commands, such as strace or dialog provide means to redirect stderr. strace has -o <filename.txt> option which allows specifying filename where output should be written. There is also an option for writing a textfile for each subprocess that strace sees. The dialog command writes the text user interface to stdout but output to stderr, so in order to save its output to variable ( because var=$(...) and pipelines only receives stderr ) we need to swap the file descriptors
result=$(dialog --inputbox test 0 0 2>&1 1>/dev/tty);
but additionally, there is --output-fd flag, which we also can utilize. There's also the method of named pipes. I recommend reading the linked post about the dialog command for thorough description of what's happening.
