197
Assuming i have a line that i want to add to a file without opening an editor.
How could i append this line
alias list='ls -cl --group-directories-first'
to this file
config.fish
NES
  • 33,935
You can append a line of text to a file by using the >> operator:
echo "hello world" >> my_file.txt
or in your case
echo "alias list='ls -cl --group-directories-first'" >> config.fish
Please take note of the different types of quotes.
There's plenty of methods of appending to file without opening text editors, particularly via multiple available text processing utilities in Ubuntu. In general, anything that allows us to perform open() syscall with O_APPEND flag added, can be used to append to a file.
  • GNU version of dd utility can append data to file with conv=notrunc oflag=append
    printf "\nalias list='ls -cl --group-directories-first'\n" | dd conv=notrunc oflag=append bs=1 of=config.fish
    Portably we could use something like this on the right side of pipeline:
    dd conv=notrunc seek=$(wc -c < testFile.txt) bs=1 of=testFile.txt
    Note the use of bs=1 , which is to prevent short reads from pipeline
  • The tee command can be used when you need to append to file and send it to stdout or to next command in pipeline
    tee -a config.fish <<< "alias list='ls -cl --group-directories-first'"
  • awk has append operator >> which is also portable and defined by POSIX specifications
    awk 'BEGIN{ printf "alias list=\x27ls -cl --group-directories-first\x27\n" >> "config.fish"  }'
  • We can combine sed's flag $ to match the last line with a for appending and -i for in-place editing.
    sed -i '$a alias list='"'"'ls -cl --group-directories-first'"'" config.fish
  • We could even implement something like dd in Python 3:
    #!/usr/bin/env python3
    # read bytes from stdin, append to specified file
    import sys
    with open(sys.argv[1],'ab') as f:
         f.write(sys.stdin.buffer.read())
See also:
Adding to Stefano's answer, you can also use cat:
  • Using a heredoc:
    $ cat >> config.fish <<'EOF'
    > EOF
    <<'EOF' means "take the following as input, until you reach a line that is just EOF". The quotes mean to take the input literally.
  • Or inputting the line on stdin:
    Then paste or type in the line, press Enter to go to a new line, then press Ctrl+D to mark the end.
wjandrea
  • 14,504
