I want my shell prompt to look like a cheeseburger!
It would be nice if it also displayed: username, hostname, and current directory.
great choice!
$ sudo apt-get install ttf-ancient-fonts
$ export PS1="\\u@\h \\w "
enjoy.
Putting a cheeseburger on the prompt:
Install a unicode font that contains this character:
Try the prompt:
Make permanent the change (if you don't do that, it will reset once terminal is closed):
nano .bashrcLocate these lines:
if [ "$color_prompt" = yes ]; then
PS1='${debian_chroot:+($debian_chroot)}\[\033[01;32m\]\u@\h\[\033[00m\]:\[\033[01;34m\]\w\[\033[00m\]\$ '
else
PS1='${debian_chroot:+($debian_chroot)}\u@\h:\w\$ '
fi
Replace \$ character a the end of the lines beginning with PS1= by the cheeseburger:
PS1='${debian_chroot:+($debian_chroot)}\[\033[01;32m\]\u@\h\[\033[00m\]:\[\033[01;34m\]\w\[\033[00m\] '
else
PS1='${debian_chroot:+($debian_chroot)}\u@\h:\w\ '
fi
Typing a cheeseburger everywhere (linux only):
u will appear.I couldn't help but take this probably a step too far. This version updates your prompt to display a different character based on time of day, to illustrate what you should be doing at that time.
declare -A pp
pp=(["09"]="" ["07"]="" ["08"]="" [10]="" [11]="" [12]="" [13]="" [14]="" [15]="" [16]="" [17]="" [18]="" [19]="" [20]="" [24]="")
u_pp() {
c=${pp[`date +"%H"`]}
if [[ $c == "" ]]; then
c=${pp[24]}
fi
PS1='\u@\h:\w${c} '
u_pp
export PROMPT_COMMAND="u_pp;"
Probably there's a more concise way to do it; my bash isn't all that great.
To add the current time of day on the left side, replace the assignment of PS1:
PS1='[\@] \u@\h:\w${c} '
If you can't install the 'ancient fonts' maybe a sideways ASCII art cheeseburger would work?
export PS1="\\u@\h \\w (||]"
Of course, there could be different ways of typing this, possibly including lettuce, pickles, etc.
You can use the following code to create a useful and colorful prompt with an ASCII art hamburger. Well... to be correct, this is a cheeseburger, red meat, with salad on white Italian bread! Special delight! ;-)
Login as the user, go to the home folder and open the bashrc file:
vim ~/.bashrc
Add or replace the following line:
export PS1="\[\e[01;37m\][\[\e[0m\]\[\e[01;32m\]\u\[\e[0m\]\[\e[00;37m\]@\[\e[0m\]\[\e[01;34m\]\h\[\e[0m\]\[\e[00;37m\] \[\e[0m\]\[\e[00;37m\]\t\[\e[0m\]\[\e[01;37m\] \W \e[1;37m(\e[1;32m|\e[1;33m|\e[1;31m|\e[1;37m]\\$ \[\e[0m\]"
Result (no colors):
[john@server003 15:39:14 ~ (|||]$
Green Cheeseburger:
export PS1='\[\e[1;32m\][\u@\h \W]\ \[\e[0m\] '
Red Cheesburger:
export PS1='\[\e[1;31m\][\u@\h \W]\ \[\e[0m\] '
Bicycle:
or
Love hearts:
Show the time on the left and a watch on the right:
export PS1="[\@] \u@\h "
Aside from pasting the emoji into the prompt definition directly, you can use the Unicode code point for cheeseburger with printf and command substitution within the prompt:
$ PS1='$(printf "\U0001f354") $ '
$ echo "Hello,my cheesy prompt!"
