PS1 is set in your ~/.bashrc. This file contains settings which will be applied in every interactive shell. An interactive Bash shell is what you get when you open a terminal in Ubuntu, unless you have set a different default shell for your user.
In an interactive shell, we need a prompt, and it's nice if the prompt gives us some useful info, like the current working directory, the current user and the hostname, as the Ubuntu PS1 does.
Here are the lines which set PS1 in the default version of .bashrc for my system, /etc/skel/.bashrc
# uncomment for a colored prompt, if the terminal has the capability; turned
# off by default to not distract the user: the focus in a terminal window
# should be on the output of commands, not on the prompt
#force_color_prompt=yes
if [ -n "$force_color_prompt" ]; then
if [ -x /usr/bin/tput ] && tput setaf 1 >&/dev/null; then
# We have color support; assume it's compliant with Ecma-48
# (ISO/IEC-6429). (Lack of such support is extremely rare, and such
# a case would tend to support setf rather than setaf.)
color_prompt=yes
else
color_prompt=
fi
fi
if [ "$color_prompt" = yes ]; then
PS1='${debian_chroot:+($debian_chroot)}\[\033[01;32m\]\u@\h\[\033[00m\]:\[\033[01;34m\]\w\[\033[00m\]\$ '
else
PS1='${debian_chroot:+($debian_chroot)}\u@\h:\w\$ '
fi
unset color_prompt force_color_prompt
From PS1='${debian_chroot:+($debian_chroot)}\u@\h:\w\$ ' you can see that the escape codes for username and hostname are \u and \h respectively
zanna@toaster:~$ PS1="\u@\h"
zanna@toaster
If you want to add the time and current working directory:
zanna@toasterPS1="\u@\h \t \w "
zanna@toaster 10:43:32 ~
To get colours, you need to use the colour escape sequences. You can see some in the color_prompt assignment in .bashrc
For example, \033[01;34m is blue:
Oops! Now the text after is blue as well... better change it back to white:
We should surround colour assignments with escaped square brackets, otherwise Bash will think they are printing characters of the prompt and use them to calculate its size. This gives weird effects when you try to interact with your history, so here's the corrected version:
PS1="\[\033[01;34m\]\u@\h \t \w \[\033[00m\]"
When you have finished playing, you can return the prompt to default by closing the terminal and opening a new one ;) or by running
source ~/.bashrc
I set my PS1 like this using the code already in .bashrc, uncommenting #force_color_prompt=yes and changing the colour codes. Here you can see the lines I have changed to set it:
$ diff .bashrc /etc/skel/.bashrc
46c46
< force_color_prompt=yes
60c60
< PS1='${debian_chroot:+($debian_chroot)}\[\033[01;32m\]\u@\h\[\033[00m\]:\[\033[01;35m\]\w\$\[\033[00m\] '
(there are more lines changed after this, but they aren't relevant)
You could do the same, but add a \t into the color_prompt line somewhere, for example
PS1='${debian_chroot:+($debian_chroot)}\[\033[01;32m\]\u@\h \[\033[01;36m\]\t \[\033[00m\]:\[\033[01;35m\]\w\$\[\033[00m\] '
For a list of ANSI escape codes for colours and more stuff, see this guide to customising the prompt.
I neglected to answer the last part of your question.
Finally, where does the export line go? I looked in the ~/.profile, but there isn't the line export PS1='\t\w\$'
I'm not sure whether you expected running export VAR=val would cause your ~/.profile to be automatically modified. The export command never does this. Exporting a variable will only pass it into the environment of commands run from the current shell. When you exit the shell (and all of its child processes have exited), anything you exported from the shell is gone.
If you want to set an environment variable permanently, you generally need to add it to ~/.profile explicitly. Some scripts you might use to install software may modify your ~/.profile or other shell configuration files.
But PS1 does not need to be exported into the environment. At the start of my answer I said that in an interactive shell we need a prompt, and I meant that only interactive shells need prompts (because the prompt helps the user interact with the shell). No other command needs PS1.
You might be thinking that it could be useful for PS1 to be passed to any child shells of the current shell. When you start an interactive shell within a shell by running bash, the new shell will not inherit the shell variables of the calling shell; only its environment variables. So, to pass variables to a child shell, we should export them.
But exporting PS1 will usually* fail to pass its value to a child shell, because it is reset by the shell's configuration files, /etc/bash.bashrc and ~/.bashrc. So, closing the terminal (as I suggested earlier) is not necessary; even running bash will return your prompt to its usual form:
zanna@toaster:~$ export PS1='\t -> '
22:43:54 -> bash
zanna@toaster:~$
(if you exit this shell, the edited prompt comes back)
* I say usually, because, although non-interactive shells always unset PS1, an interactive Bash shell will preserve the value of PS1 if it is set. This isn't obvious, because as shown in the preceding example it typically gets reset by the configuration files. We can uncover it by changing PS1 and then starting a new shell that doesn't read our config files:
22:55:04 -> bash --norc
22:55:09 ->
So, to conclude, there is no export line for PS1 in ~/.profile because PS1 is not an environment variable and has no business being one, since only interactive shells need it, and for the reason that interactive shells need PS1, it is set in ~/.bashrc, because unless told not to, all interactive Bash shells source ~/.bashrc, so ~/.bashrc doesn't need to export PS1 to be inherited by child shells (but if you do really want to export some value of PS1 other than the one in your .bashrc to a child shell, you can do so by preventing that shell from sourcing .bashrc).
I have been able to extend my answer thanks to Eliah Kagan, who explained how Bash treats PS1 here in chat and in more detail in this answer.
