Sometimes, and I can't reproduce it (but it happens often enough - a few times a week at least) my cpu slows down below its prescribed minimum. This is an example cpufreq-info output from a minute ago:
cpufrequtils 008: cpufreq-info (C) Dominik Brodowski 2004-2009
Report errors and bugs to cpufreq@vger.kernel.org, please.
analyzing CPU 0:
driver: intel_pstate
CPUs which run at the same hardware frequency: 0
CPUs which need to have their frequency coordinated by software: 0
maximum transition latency: 0.97 ms.
hardware limits: 800 MHz - 3.30 GHz
available cpufreq governors: performance, powersave
current policy: frequency should be within 800 MHz and 3.30 GHz.
The governor "powersave" may decide which speed to use
within this range.
current CPU frequency is 610 MHz.
analyzing CPU 1:
CPUs which run at the same hardware frequency: 1
CPUs which need to have their frequency coordinated by software: 1
within this range.
current CPU frequency is 615 MHz.
analyzing CPU 2:
CPUs which run at the same hardware frequency: 2
CPUs which need to have their frequency coordinated by software: 2
within this range.
current CPU frequency is 590 MHz.
analyzing CPU 3:
CPUs which run at the same hardware frequency: 3
CPUs which need to have their frequency coordinated by software: 3
within this range.
current CPU frequency is 589 MHz.
The problem is that it really slows everything down. Firefox becomes slower, vim's startup time grows from 150-250ms to above 700ms, g++ compilations become three times slower, etc.
Restart fixes everything.
Some error line from the past couple of hours from my syslog:
May 17 16:10:53 lati kernel: [ 1421.872755] ACPI Error: Index value 0x0000000000000083 overflows field width 0x7 (20140424/exfldio-343)
May 17 16:10:53 lati kernel: [ 1421.872758] ACPI Error: Method parse/execution failed [\NEVT] (Node ffff88040e047258), AE_AML_REGISTER_LIMIT (20140424/psparse-536)
May 17 16:10:53 lati kernel: [ 1421.872761] ACPI Error: Method parse/execution failed [\_SB_.PCI0.LPCB.ECDV._Q66] (Node ffff88040e044b90), AE_AML_REGISTER_LIMIT (20140424/psparse-536)
May 17 16:10:56 lati kernel: [ 1425.907749] ACPI Error: Index value 0x0000000000000083 overflows field width 0x7 (20140424/exfldio-343)
May 17 16:10:56 lati kernel: [ 1425.907765] ACPI Error: Method parse/execution failed [\NEVT] (Node ffff88040e047258), AE_AML_REGISTER_LIMIT (20140424/psparse-536)
May 17 16:10:56 lati kernel: [ 1425.907794] ACPI Error: Method parse/execution failed [\_SB_.PCI0.LPCB.ECDV._Q66] (Node ffff88040e044b90), AE_AML_REGISTER_LIMIT (20140424/psparse-536)
May 17 16:12:09 lati kernel: [ 1.925333] EXT4-fs (sda5): re-mounted. Opts: errors=remount-ro
May 17 16:12:09 lati kernel: [ 2.421037] systemd-udevd[331]: Error calling EVIOCSKEYCODE: Invalid argument
May 17 16:12:21 lati gnome-session[2251]: WARNING: Could not parse desktop file tracker-store.desktop or it references a not found TryExec binary
May 17 16:12:21 lati gnome-session[2251]: WARNING: Could not parse desktop file tracker-miner-fs.desktop or it references a not found TryExec binary
May 17 16:12:51 lati gnome-session[2251]: GLib-CRITICAL: g_environ_setenv: assertion 'value != NULL' failed
May 17 17:48:19 lati kernel: [ 5769.576717] systemd-hostnamed[6983]: Warning: nss-myhostname is not installed. Changing the local hostname might make it unresolveable. Please install nss-myhostname!
I am using Ubuntu 14.04.2, fresh install, 64bit, on Dell E7440, bios version A14.
By the way, even the execution of lsb_release, when I'm on this mode, is taking about 400ms.
Extra info
- My processor model name: Intel(R) Core(TM) i7-4600U CPU @ 2.10GHz
- My processor model number: 69
- It probably occurs only after a suspend, but usually it doesn't happen (for example, it has happened only once since I've asked this question).
Extra info (2)
Output from grep -r . * in /sys/class/thermal:
cooling_device0/type:Processor
cooling_device0/power/control:auto
cooling_device0/power/async:disabled
cooling_device0/power/runtime_enabled:disabled
cooling_device0/power/runtime_active_kids:0
cooling_device0/power/runtime_active_time:0
cooling_device0/power/runtime_status:unsupported
cooling_device0/power/runtime_usage:0
cooling_device0/power/runtime_suspended_time:0
cooling_device0/cur_state:0
cooling_device0/max_state:3
cooling_device1/type:Processor
cooling_device1/power/control:auto
cooling_device1/power/async:disabled
cooling_device1/power/runtime_enabled:disabled
cooling_device1/power/runtime_active_kids:0
cooling_device1/power/runtime_active_time:0
cooling_device1/power/runtime_status:unsupported
cooling_device1/power/runtime_usage:0
cooling_device1/power/runtime_suspended_time:0
cooling_device1/cur_state:0
cooling_device1/max_state:3
cooling_device2/type:Processor
cooling_device2/power/control:auto
cooling_device2/power/async:disabled
cooling_device2/power/runtime_enabled:disabled
cooling_device2/power/runtime_active_kids:0
cooling_device2/power/runtime_active_time:0
cooling_device2/power/runtime_status:unsupported
cooling_device2/power/runtime_usage:0
cooling_device2/power/runtime_suspended_time:0
cooling_device2/cur_state:0
cooling_device2/max_state:3
cooling_device3/type:Processor
cooling_device3/power/control:auto
cooling_device3/power/async:disabled
cooling_device3/power/runtime_enabled:disabled
cooling_device3/power/runtime_active_kids:0
cooling_device3/power/runtime_active_time:0
cooling_device3/power/runtime_status:unsupported
cooling_device3/power/runtime_usage:0
cooling_device3/power/runtime_suspended_time:0
cooling_device3/cur_state:0
cooling_device3/max_state:3
cooling_device4/type:intel_powerclamp
cooling_device4/power/control:auto
cooling_device4/power/async:disabled
cooling_device4/power/runtime_enabled:disabled
cooling_device4/power/runtime_active_kids:0
cooling_device4/power/runtime_active_time:0
cooling_device4/power/runtime_status:unsupported
cooling_device4/power/runtime_usage:0
cooling_device4/power/runtime_suspended_time:0
cooling_device4/cur_state:-1
cooling_device4/max_state:50
thermal_zone0/mode:enabled
thermal_zone0/temp:25000
thermal_zone0/type:acpitz
thermal_zone0/power/control:auto
thermal_zone0/power/async:disabled
thermal_zone0/power/runtime_enabled:disabled
thermal_zone0/power/runtime_active_kids:0
thermal_zone0/power/runtime_active_time:0
thermal_zone0/power/runtime_status:unsupported
thermal_zone0/power/runtime_usage:0
thermal_zone0/power/runtime_suspended_time:0
thermal_zone0/trip_point_0_temp:107000
thermal_zone0/trip_point_0_type:critical
thermal_zone0/policy:step_wise
thermal_zone0/passive:0
thermal_zone1/temp:47000
thermal_zone1/type:x86_pkg_temp
thermal_zone1/power/control:auto
thermal_zone1/power/async:disabled
thermal_zone1/power/runtime_enabled:disabled
thermal_zone1/power/runtime_active_kids:0
thermal_zone1/power/runtime_active_time:0
thermal_zone1/power/runtime_status:unsupported
thermal_zone1/power/runtime_usage:0
thermal_zone1/power/runtime_suspended_time:0
thermal_zone1/trip_point_0_temp:0
thermal_zone1/trip_point_0_type:passive
thermal_zone1/trip_point_1_temp:0
thermal_zone1/trip_point_1_type:passive
thermal_zone1/policy:step_wise
