466
Is there a way to change the date when a file was modified/created (which is shown in Nautilus or with the ls -l command)? Ideally I am looking for a command which can change the date/time stamps of a whole bunch of files to a certain amount of time earlier or later (e.g. +8 hours or -4 days etc.).
david6
  • 14,528
  • 38
  • 46
snej
  • 4,661
6 Answers6
587
As long as you are the owner of the file (or root), you can change the modification time of a file using the touch command:
touch filename
By default this will set the file's modification time to the current time, but there are a number of flags, such as the -d flag to pick a particular date. So for example, to set a file as being modified two hours before the present, you could use the following:
touch -d "2 hours ago" filename
If you want to modify the file relative to its existing modification time instead, the following should do the trick:
touch -d "$(date -R -r filename) - 2 hours" filename
If you want to modify a large number of files, you could use the following:
find DIRECTORY -print | while read filename; do
    # do whatever you want with the file
    touch -d "$(date -R -r "$filename") - 2 hours" "$filename"
done
You can change the arguments to find to select only the files you are interested in. If you only want to update the file modification times relative to the present time, you can simplify this to:
find DIRECTORY -exec touch -d "2 hours ago" {} +
This form isn't possible with the file time relative version because it uses the shell to form the arguments to touch.
As far as the creation time goes, most Linux file systems do not keep track of this value. There is a ctime associated with files, but it tracks when the file metadata was last changed. If the file never has its permissions changed, it might happen to hold the creation time, but this is a coincidence. Explicitly changing the file modification time counts as a metadata change, so will also have the side effect of updating the ctime.
162
Easiest way - accessed and modified will be the same:
touch -a -m -t 201512180130.09 fileName.ext
Where:
-a = accessed
-m = modified
-t = timestamp - use [[CC]YY]MMDDhhmm[.ss] time format
If you wish to use NOW just drop the -t and the timestamp.
To verify they are all the same: stat fileName.ext
See: man touch
Jadeye
  • 2,342
65
Thanks for the help. This worked for me:
In the terminal go to the directory for date-edit. Then type:
find -print | while read filename; do
    touch -t 201203101513 "$filename"
done
You wil see a ">" after you hit enter, exept for the last time -> "done".
Note: You may want to change "201203101513"
"201203101513" = is the date you want for all the files in this directory.
boroboris
  • 101
EFL
  • 751
24
Touch can reference a file's date all by itself, no need to call date or use command substitution. Here's a bit from touch's info page:
`-r FILE' `--reference=FILE'
     Use the times of the reference FILE instead of the current time.
     If this option is combined with the `--date=TIME' (`-d TIME')
     option, the reference FILE's time is the origin for any relative
     TIMEs given, but is otherwise ignored.  For example, `-r foo -d
     '-5 seconds'' specifies a time stamp equal to five seconds before
     the corresponding time stamp for `foo'.  If FILE is a symbolic
     link, the reference timestamp is taken from the target of the
     symlink, unless `-h' was also in effect.
For example, to add 8 hours to a file's date (filename of file quoted just in case of spaces, etc):
touch -r "file" -d '+8 hour' "file"
Using a loop over all files in the current dir:
for i in *; do touch -r "$i" -d '+8 hour' "$i"; done
I've heard that using a * and letting for pick the filenames itself is safer, but using find -print0 | xargs -0 touch ... should handle most crazy characters like newlines, spaces, quotes, backslashes in a filename. (PS. try not to use crazy characters in filenames in the first place).
For example, to find all files in thatdir whose filenames start with an s, and add one day to those file's modified timestamp, use:
find thatdir -name "s*" -print0 | xargs -0 -I '{}' touch -r '{}' -d '+1 day' '{}'
Xen2050
  • 8,943
This little script at least works for me:
#!/bin/bash
find specific files
files=$(find . -type f -name '*.JPG')
use newline as file separator (handle spaces in filenames)
IFS=$'\n'
for f in ${files} do
read file modification date using stat as seconds
adjust date backwards (1 month) using date and print in correct format
change file time using touch
touch -t $(date -v -1m -r $(stat -f %m "${f}") +%Y%m%d%H%M.%S) "${f}" done
Pablo Bianchi
  • 17,371
joakim
  • 51
It's been a long time since I wrote any kind of Unix program, but I accidentally set the year incorrectly on a bunch of Christmas photos, and I knew if I didn't change the date from 2015 to 2014 it would be a problem later on.
Maybe, this is an easy task, but I didn't find any simple way to do it.
I modified a script I found here, which originally was used to modify the date by minus one month.
Here's the original script:
#!/bin/bash
# find specific files
# use newline as file separator (handle spaces in filenames)
IFS=$'\n'
for f in ${files}
do
 # read file modification date using stat as seconds
 # adjust date backwards (1 month) using date and print in correct format
 # change file time using touch
done
Here's my modified script that forced the date to the year "2014":
#!/bin/bash
#files=$(find . -type f -name '*.JPG')
IFS=$'\n'
for f in $*
do
 touch -t $(date -v +1y -r $(stat -f %m  "${f}") +2014%m%d%H%M.%S) "${f}"
done
I now realize I could have done a more generic version:
#!/bin/bash
IFS=$'\n'
for f in $*
do
 # change file time using touch (+1y adds a year "-1y" subtracts a year)
 # Below line subtracts a year
 touch -t $(date -v -1y -r $(stat -f %m  "${f}") +%Y%m%d%H%M.%S) "${f}"
 # Below line adds a year
 # touch -t $(date -v +1y -r $(stat -f %m  "${f}") +%Y%m%d%H%M.%S) "${f}"
done
To use this file you would need to write it and
chmod +x fn
to execute:
./fn files-to-change
fn=your-file-name-that-is-your-command
Example
./fn *.JPG
will change the date by minus one year in the directory where you are.
Eric Carvalho
  • 55,453
RickK
  • 31
