On Ubuntu Gnome 15.04, Gparted will not launch from the icon. When launched from the terminal it gives the error 'Segmentation fault (core dumped)'.
It works fine on Ubuntu & Ubuntu Mate 15.04.
Ceorl
  • 133
The problem is the library libglibmm, better libglibmm-2.4-1c2a
Check the output of this command:
apt-cache policy libglibmm-2.4-1c2a
Sample output:
% apt-cache policy libglibmm-2.4-1c2a
libglibmm-2.4-1c2a:
  Installed: 2.43.2-0ubuntu1~vivid1
  Candidate: 2.43.2-0ubuntu1~vivid1
  Version table:
 *** 2.43.2-0ubuntu1~vivid1 0
        500 http://ppa.launchpad.net/gnome3-team/gnome3-staging/ubuntu/ vivid/main amd64 Packages
        100 /var/lib/dpkg/status
     2.42.0-1 0
        500 http://archive.ubuntu.com/ubuntu/ vivid/main amd64 Packages
Install an older version, eg: 2.42.0-1
sudo apt-get install libglibmm-2.4-1c2a=2.42.0-1
and set the package on hold:
sudo apt-mark hold libglibmm-2.4-1c2a
reversible with
sudo apt-mark unhold libglibmm-2.4-1c2a
That worked in my case.
Output of gdbgpartedbin`
Starting program: /usr/sbin/gpartedbin
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
Program received signal SIGSEGV, Segmentation fault.
0x00007ffff6a6993a in Glib::wrap_register(unsigned long, Glib::ObjectBase* (*)(_GObject*)) () from /usr/lib/x86_64-linux-gnu/libglibmm-2.4.so.1
(gdb) bt
#0 0x00007ffff6a6993a in Glib::wrap_register(unsigned long, Glib::ObjectBase* (*)(_GObject*)) () from /usr/lib/x86_64-linux-gnu/libglibmm-2.4.so.1
#1 0x00007ffff6a5969e in Glib::wrap_init() () from /usr/lib/x86_64-linux-gnu/libglibmm-2.4.so.1
#2 0x0000000000418ebf in ?? ()
#3 0x00007ffff49aea40 in __libc_start_main (main=0x418e90, argc=1, argv=0x7fffffffe338, init=<optimized out>, fini=<optimized out>, rtld_fini=<optimized out>, stack_end=0x7fffffffe328) at libc-start.c:289
#4 0x0000000000419575 in ?? ()
A.B.
  • 92,125
