102
In order to search for a process you can use ps with grep.
For example to search for firefox
ps aux | grep firefox
How to get the same answer without using grep?
muru
  • 207,228
Maythux
  • 87,123
8 Answers8
113
The pgrep command, and its sibling pkill, exists precisely for this purpose:
  • pgrep firefox will list all processes whose commands match firefox
  • pgrep -f firefox will list all processes whose entire command lines match firefox
  • pgrep -x firefox will list all processes whose commands exactly match firefox
  • ... and so on.
And naturally, pgrep will exclude itself from the match, so none of the grep rituals associated with ps | grep are needed.
The other set of tools for this are the pidof and killall commands. These aren't as flexible as pgrep and pkill.
  • pidof firefox will list processes whose command is firefox
muru
  • 207,228
39
ps -fC process-name
example:
ps -fC firefox
from man ps
  -C cmdlist      Select by command name.
                       This selects the processes whose executable name is
                       given in cmdlist.
 -f              Do full-format listing. This option can be combined
                       with many other UNIX-style options to add additional
                       columns. It also causes the command arguments to be
                       printed. When used with -L, the NLWP (number of
                       threads) and LWP (thread ID) columns will be added. See
                       the c option, the format keyword args, and the format
                       keyword comm.
Maythux
  • 87,123
A cool trick
$ps -ejH
You will get all the processes with names
exmple:
1747   568   568 ?        00:00:00   colord
1833  1832  1832 ?        00:00:00   gnome-keyring-d
2263   568   568 ?        00:00:00   udisksd
2311  2311  2311 ?        00:00:00   cupsd
2315  2315  2311 ?        00:00:00     dbus
Redirect or so copy the output to a file and then open nano, press Ctrl+W and you can search for the name you want.
Zanna
  • 72,312
daniel
  • 161
top allows you to search for string when you hit uppercase L; the process will be highlighted, and use up and down arrow keys to scroll through list of processes. Similarly, htop command allows highlighting a particular process when you hit /. And \ will filter all the processes with a particular string in the name.
For those who like awk, here's an awk oneliner: ps -eF | awk '/process-name/ {print $11}' . With ps -eF process name is always in 11th column. Alternatively if you do ps -eF | awk '{print $11}' | sort you get a sorted list of processes names, sorted alphabetically. Pipe it into less command just to view the long list of files easier.
If the reason you don't want to use ps | grep is because it loses the first line (the column headers), you can do:
ps aux | grep 'firefox\|^USER'
This is grepping for a line that contains firefox or a line that starts with USER (the first line of header line on my distro).
Kip
  • 121
You can also use htop and then hit F4 to filter the results with a matching user-defined string. You also have a custom search feature available by hitting F3.
JoErNanO
  • 121
If two processes is the problem, you can use only grep:
grep firefox /proc/*/cmdline
I just read this ps alias on the Lennart Poettering Blog. The output is according to the systemd control group parenting:
alias psc='ps xawf -eo pid,user,cgroup,args'
wjandrea
  • 14,504
