The specific find command I am trying to kill is running inside of a user created script?
I created a script that inside of it, it contains a find command that runs for up to 10 minutes, before I run that same script again, it needs to kill that find command.
Seth
  • 59,332
pgrep
You can use pgrep with -a switch:
pgrep -a find
it will give you a full command line as well as the process ID:
10838 find / -iname png
10839 find / -iname jpg
then you can decide if it's the one you want to kill or not:
kill 10838
will kill the png one.
pkill
you can also use pkill like this:
pkill -x "find / -iname png"
-x means: Only match processes whose names.
Find child process:
use tree to find your desired process, let's say your script name is "script.sh" you can use pgrep -f script to find it, then pass the output to pstree to get a list of it's child and kill the find process which is the child of your script.
$ pstree -p $(pgrep -f script)
bash(10915)───find(10916)
$ kill 10916
Ravexina
  • 57,256
