I want to know if there are other users that are running watch on the same machine in which command X is being executed. How can I do that?
To see what processes are running on a machine, you can use ps. This is a command with a huge number of options, so you might want to take a look at man ps to learn a little about it.
To check whether anyone is running watch, you would do:
$ ps aux | grep -w watch
terdon 15915 0.0 0.0 15912 2676 pts/4 S+ 15:58 0:00 watch ls
terdon 16123 0.0 0.0 13948 2264 pts/5 S+ 15:58 0:00 grep --color -w watch
The -w tells grep to only match whole words. Otherwise, processes like watchdog would also be listed. However, that also returns the grep process itself. To avoid that, you can use pgrep:
$ pgrep -xl watch
15915 watch
The -x makes it look for exact matches only and the -l makes it also list the process name and not just its PID.
Now, if you want to check for both MyOwnCommand and watch, you could do:
$ pgrep MyOwnCommand >/dev/null && pgrep -xl watch
15915 watch
The && means that the second pgrep will only be run if the first was successful, if MyOwnCommand is running. The >/dev/null discards the output of the first pgrep.
- 104,119
