I use ubuntu 14.04LTS, when I type in:
sudo apt-get install vlc
I receive this error:
Reading package lists... Done
Building dependency tree
vlc : Depends: vlc-nox (= 3.0.0~~git20150319+r59816+33~ubuntu14.04.1) but it is not going to be installed
Depends: libavcodec55 (>= 6:9.1-1) but it is not installable or
libavcodec-extra-55 (>= 6:10~~git20131218.b3189af~ubuntu14.04.1) but it is not installable
Depends: libavutil53 (>= 6:9.1-1) but it is not installable
Recommends: vlc-plugin-notify (= 3.0.0~~git20150319+r59816+33~ubuntu14.04.1) but it is not going to be installed
Recommends: vlc-plugin-samba (= 3.0.0~~git20150319+r59816+33~ubuntu14.04.1) but it is not going to be installed
