Whenever I try to install VLC by terminal this shows up.
ankit@ankit-desktop:~$ sudo apt-get install vlc
[sudo] password for ankit:
Reading package lists... Done
Building dependency tree
 vlc : Depends: vlc-nox (= 2.0.8+git20131023+r618-0~r13~ubuntu13.10.1) but it is not going to be installed
       Recommends: vlc-plugin-notify (= 2.0.8+git20131023+r618-0~r13~ubuntu13.10.1) but it is not going to be installed
       Recommends: vlc-plugin-pulse (= 2.0.8+git20131023+r618-0~r13~ubuntu13.10.1) but it is not going to be installed
I'm using Ubuntu 13.10.
Please tell me what to do?
When I try to install VLC from software center, this message pops up, Package dependencies cannot be resolved.
Tim
  • 33,500
Ankit
You have most likely set up a new machine and encrypted your system.
  1. Press ALT and F2 together.
  2. Type--> software-properties-gtk and select it.
  3. Select the other sources tab.
  4. Make sure the boxes that say "canonical partners" and "canonical partners (source code)" are both checked.
  5. Agree to the requested update.
You should now be able to install vlc.
bummi
  • 394
Try to run:
sudo apt-get -f install
This should fix broken packages or unmet dependencies. Then you can go about installing vlc.
It seems you have Third party PPAs enabled. Disable them. See this question
Now refresh your package list with sudo apt-get update and do sudo apt-get install -f to solve the problem.
Anwar
  • 77,855
