I am running TeX Live 2012 on Ubuntu Precise. For the installation I followed this tutorial. Yesterday, I updated the packages (about 40 items) for Tex Live 2012 using the following tool.
$ sudo tlmgr --gui
The updates have been installed successfully and everything still worked.
Today, I noticed that apt-get outputs errors when I run sudo apt-get install something or sudo apt-get autoremove. Here is the console output of the latter command.
$ sudo apt-get autoremove
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
3 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up texlive-base (2009-15) ...
mktexlsr: Updating /var/lib/texmf/ls-R-TEXMFMAIN...
mktexlsr: Updating /var/lib/texmf/ls-R-TEXLIVE...
mktexlsr: Updating /var/lib/texmf/ls-R...
mktexlsr: Done.
texconfig: unknown option `paperconf' given as argument for `texconfig dvips'
texconfig: try `texconfig dvips' for help
texconfig: unknown option `paperconf' given as argument for `texconfig dvipdfmx'
texconfig: try `texconfig dvipdfmx' for help
texconfig: unknown option `paperconf' given as argument for `texconfig xdvi'
texconfig: try `texconfig xdvi' for help
texconfig: unknown option `paperconf' given as argument for `texconfig pdftex'
texconfig: try `texconfig pdftex' for help
dpkg: error processing texlive-base (--configure):
 subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of texlive-latex-base:
 texlive-latex-base depends on texlive-base (>= 2009-1); however:
  Package texlive-base is not configured yet.
dpkg: error processing texlive-latex-base (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of texlive-bibtex-extra:
 texlive-bibtex-extra depends on texlive-latex-base (>= 2009-1); however:
  Package texlive-latex-base is not configured yet.
dpkg: error processing texlive-bibtex-extra (--configure):
No apport report written because the error message indicates its a followup
error from a previous failure.
 texlive-base
 texlive-latex-base
LaTeX itself still works fine as far as I can see.
Note: Just in case the following has something to do with the main problem. I also noticed a while ago that the man path does no longer point to the usual folders. The MANPATH problem has been described before. However, I could not solve it on my machine.
$ echo $MANPATH
/usr/local/texlive/2012/texmf/doc/man
JJD
  • 882
Finally, I uninstalled all TexLive-related packages which let the error messages disappear. Here is what I did ...
sudo apt-get remove tex-common texlive-base texlive-binaries texlive-common \
  texlive-doc-base texlive-latex-base texlive-local texlive-latex-base-doc
sudo apt-get autoclean
I will probably use the advertised texlive-backports PPA to reinstall TexLive.
I also found out that the MANPATH problem originated from a custom configuration I made somewhen. This was indirectly loaded from my .zshrc file.
# TexLive 2012
export MANPATH=/usr/local/texlive/2012/texmf/doc/man
JJD
  • 882
