I have a Dell N5010 15R with a 64-bit i3 processor, Intel HD graphics, 320GB hard drive and integrated network card. I wanted to know which Ubuntu version to install in order to have the capacity to use the HD integrated graphics card's full potential.
I want to get in Ubuntu and stop using Windows 7, but will it run programs like FL Studio or Vegas Studio Pro or similar?
Daniel
  • 31
The hardware should work nicely with Ubuntu. You're mentioning Windows applications, and those will not normally run in Ubuntu at all. However, there is something called Wine, which can be used to use Windows applications on Ubuntu. Not everything will work, and not everything will run nicely. You can have a look at http://appdb.winehq.org and search for the applications you need.
Any Ubuntu flavor will work with your Laptop, They are all the same it's just the GUI and default software (read: Desktop Environment) that's different.
About running FL Studio with WINE: according to WineHQ it runs almost flawlessly. Vegas Studio however won't run at all (except version 9.0e)
Uri Herrera
  • 15,318
You should download and try a live-cd and test it before you touch the hardrive. Just keep in mind than the performance will be even better if you decide to install it on the hardrive. Ubuntu would run like a charm on your configuration (my main computer broke some days ago and right now I'm running it in an old pentium 4 with only 300 mb ram and everything works, so imagine in your i3...)
Also, you could make a dual boot system if you want to keep win7 just in case you change your mind later (but I don't think you do). There's hundreds of tutorials about it.
I have a 17R, bought a month or so ago, so the hardware's probably pretty similar. The only thing with which I've had a problem is the touchpad -- the protocol used by the touchpad isn't entirely reverse-engineered yet. This means the touchpad will still work, even with side-scrolling, but some of touchpad-specific features (like turning it off when you are typing) are still under (quite active) development.
Ben Kraft
  • 196
