15
malikarumi@Tetouan2:~$ pip install virtualenv
    Collecting virtualenv
    Downloading virtualenv-12.0.7-py2.py3-none-any.whl (1.8MB)
    100% |################################| 1.8MB 330kB/s
malikarumi@Tetouan2:~$ pip freeze
    (a lot of stuff, but not virtualenv)
malikarumi@Tetouan2:~$ virtualenv testvenv1
    The program 'virtualenv' is currently not installed. You can install it by typing:
    sudo apt-get install python-virtualenv
What is going on here? is python-virtualenv == pyvenv? Isn't that still broken? Does original virtualenv still work with python? if venv (too many name variations!!!) is part of the standard library, https://docs.python.org/3/library/venv.html, why am I being told to install it?
And when I did try to install it, I got:
malikarumi@Tetouan2:~$ sudo apt-get install python-virtualenv
    Reading package lists... Done
    Building dependency tree
    The following extra packages will be installed:
    python-colorama python-distlib python-html5lib python-pip python-setuptools
At which point I aborted, because installing python3-pip just before that had given me
Setting up python3-setuptools (3.3-1ubuntu1) ...
Setting up python3-pip (1.5.4-1) ...
And I wasn't sure if the extra packages would overwrite them or go onto python 2.7.
I read that python 3 is supposed to be the default going forward. Since both 2.7 and 3.4 are there, and have separate commands, how do I not only make sure Python 3 is my default, but that anything I install goes there and is used by it instead of 2.7?
BTW, I tried sudo apt-get python3-virtualenv and got: E: Unable to locate package python3-virtualenv
The way to install Python 3.x packages in a Python virtual environment is to create the Python virtual environment using Python 3 virtual environment creator (python3-virtualenv). python3-virtualenv is in the default Ubuntu repositories in Ubuntu 14.10 and later.
Install Python 3.x packages in a Python virtual environment in 16.04 and later
  1. Install Python 3 virtual environment creator
     sudo apt install virtualenv python3-virtualenv
  2. Create a Python virtual environment for python3. You can only install python3 packages inside this Python virtual environment. If you also want to install Python 2.x packages, then you need to make another Python virtual environment.
     virtualenv -p python3 venv
     source ./venv/bin/activate
    The new Python virtual environment for python3 will be created in the venv directory which is located in the current directory.
  3. Install Python packages.
    cd /path/to/venv/ # venv is the python3 virtual environment's directory
     source bin/activate
     python3 -m pip install first-package-name next-package-name last-package-name
This is a new python3 virtual environment with the latest version of pip3, so installing Python packages in it will work great.
Install Python 3.x packages in a Python virtual environment in Ubuntu 14.04
sudo apt-get install virtualenvwrapper
gedit .bashrc
Add the following line to the end of .bashrc.
source /usr/share/virtualenvwrapper/virtualenvwrapper.sh
Save the changes to .bashrc and close gedit. Source your .bashrc for the changes to take effect.
cd
source .bashrc
mkvirtualenv py3 -p /usr/bin/python3
The new Python virtual environment for python3 will be created in the ~/.virtualenvs/py3 directory. .virtualenvs is a hidden folder.
Install a package.
cd ~/.virtualenvs/py3
source bin/activate
python2 -m pip install package-name
karel
  • 122,292
  • 133
  • 301
  • 332
Well, it gets complicated. The following is shown against Ubuntu Xenial (which is underlying release for Linux Mint I use). Let's sort it out:
pyvenv
It refers to the Python 3.3+ stdlib package's wrapper script. But it was deprecated since Python 3.6.
It is also a PyPi package, which is a virtual environment switcher.
venv
It's the Python 3.3+ stdlib package whose purpose was to improve and replace the PyPi virtualenv package (see PEP 405). But it seems it's not there yet (at least not as feature-complete).
python-virtualenv and virtualenv
$ apt-cache show virtualenv | grep Depends
Depends: python3, python3-virtualenv
As you can see it runs on Python 3. python-virtualenv package is meant to be used like python2 -m virtualenv py2. Let's see how virtualenv works on fresh Ubuntu Xenial (docker run --rm -it ubuntu:xenial):
$ virtualenv
bash: virtualenv: command not found
$ apt-get update
$ apt-get install --yes --no-install-recommends virtualenv
The following additional packages will be installed:
  ca-certificates dh-python libexpat1 libmpdec2 libpython3-stdlib
  libpython3.5-minimal libpython3.5-stdlib libsqlite3-0 libssl1.0.0
  mime-support openssl python-pip-whl python3 python3-minimal
  python3-pkg-resources python3-virtualenv python3.5 python3.5-minimal
Suggested packages:
  libdpkg-perl python3-doc python3-tk python3-venv python3-setuptools
  python3.5-venv python3.5-doc binutils binfmt-support
Recommended packages:
  file
The following NEW packages will be installed:
  virtualenv
$ virtualenv test
The executable python2 (from --python=python2) does not exist
$ virtualenv -p python3 py3
Already using interpreter /usr/bin/python3
Using base prefix '/usr'
New python executable in /py3/bin/python3
Also creating executable in /py3/bin/python
Installing setuptools, pkg_resources, pip, wheel...done.
$ . py3/bin/activate
(py3) $ python --version
Python 3.5.2
(py3) $ deactivate
$ apt-get install --yes --no-install-recommends python
  libffi6 libpython-stdlib libpython2.7-minimal libpython2.7-stdlib
  python-minimal python2.7 python2.7-minimal
Suggested packages:
  python-doc python-tk python2.7-doc binutils binfmt-support
  libffi6 libpython-stdlib libpython2.7-minimal libpython2.7-stdlib python
$ virtualenv py2
Running virtualenv with interpreter /usr/bin/python2
New python executable in /py2/bin/python2
Also creating executable in /py2/bin/python
$ . py2/bin/activate
(py2) $ python --version
Python 2.7.12
As you can see even though virtualenv package is using python3-virtualenv, its default is to create Python 2 environment.
muru
  • 207,228
saaj
  • 255
