I have a problem when installing Buster via PIP.
I think that the problem is related with Python. PIP choose Python2 but how can PIP use Python 3?
Here is the error in the command line after pip install buster; Command /usr/bin/python -c "import setuptools, tokenize;__file__='/tmp/pip_build_felixinx/buster/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-ZR6weF-record/install-record.txt --single-version-externally-managed --compile failed with error code 1 in /tmp/pip_build_felixinx/buster Storing debug log for failure in /home/felixinx/.pip/pip.log
And here is the log (/home/felixinx/.pip/pip.log);
Too long so I put it in Github Gist... pip.log
Thanks
This installation is failing because lack of permissions.
creating /usr/local/lib/python2.7/dist-packages/buster
error: could not create '/usr/local/lib/python2.7/dist-packages/buster': Permission denied
Did you install it with sudo?:
sudo pip install buster
Javier Rivera
  • 35,434
