14
There are a number of items that I found during the search, like: Ubuntu how can I send my audio output, to the mobile which is connected using bluetooth?
There is an answer with +100, stating that Android lacks the A2DP capabilty. As far as I can make out, in the meantime there is an applet by the name of SoundAbout that is supposed to do just that. I installed it, paired the devices.
And what I get is like the image in https://cjenkins.wordpress.com/2013/07/16/use-a-wireless-bluetooth-speaker-on-ubuntu-12-04/ , except it says A2DP source (Receive Audio)
I have installed blueman, and I get quite a lot, but no other output device ever pops up in pavucontrol. Therefore, everything is and remains quiet. pulseaudio-module-bluetooth is installed.
How can I get to make the sound system see the device?
Thanks in advance!
udippel
  • 303
I think you misunderstood what SoundAbout is - its not an A2DP profile for your android bluetooth stack - its an audio router that allows you to configure how audio generated in the android device is routed, very similar to what pulseaudio does (possibly it uses pulseaudio?).
What you want is not possible with stock android, because the Bluetooth stack on Android does not support the A2DP sink profile. See this question for further explenation on that and how to create an application that enables bluetooth A2DP sink.
You might get ahead more by replacing the default Android bluetooth stack with the bluez stack used on modern Linux distribution, though it does require replacing the kernel which you can only do if you have a rooted or customized device. see here for details.
Guss
  • 3,775
Have you considered setting up a DLNA server instead?
Currently, I use MiniDLNA to run a media server that can stream music to devices that can use DLNA. There are apps for Android that provide DLNA clients, like UPnPlay.
MiniDLNA is now called ReadyMedia, but the software is still called minidlna(d). It's very easy to set up through a config file.
https://sourceforge.net/projects/minidlna/
https://help.ubuntu.com/community/MiniDLNA
Chris S.
  • 323
-1
Have you made your device's Bluetooth visible. In your Android Phone go to
Settings --> Bluetooth --> Make Visible
If you have already did this, try to reboot your computer and your phone and try again.
konmal88
  • 333
