Copy stdout to the clipboard without installing additional software
Although it seemed impossible to me at first (and it is a bit of a detour), it is very well possible without additional software. The only thing needed is python, like it is installed from a fresh install.
This solution uses python's ability to copy text to the clipboard, and make it available to other applications, as explained (a.o.) here.
The construction
- The first step is to create an empty textfile, let's say
terminal_log.txt
The command(s) that run in the terminal are followed by | tee /path/to/terminal_log.txt, e.g.
pwd | tee /path/to/terminal_log.txt
The output will be in the terminal, as well as written to terminal_log.txt
- Meanwhile, a script (see below) runs in the background, detecting changes to the file
- If the file is changed, the change will be copied to the clipboard
The result of the example above:
If I open gedit and press Ctrl+V
/home/jacob/Desktop
How to setup
- create an empty (log-) file,
terminal_log.txt
- Copy the script below into an empty file. In the head section, set the path to
terminal_log.txt, save it as read_output.py
Start the script with the command
python /path/to/read_output.py
Run in (another) terminal your command, followed by:
The output of your command is copied to the clipboard
If you use it frequently, you could run it as a startup application.
The script
#!/usr/bin/env python
import pygtk
pygtk.require('2.0')
import gtk
import time
#--- enter the path to the log file below
f = "/path/to/terminal_log.txt"
output1 = open(f).read().strip()
while True:
time.sleep(1)
output2 = open(f).read().strip()
if output1 != output2:
tx = output2.replace(output1, "")
clipboard = gtk.clipboard_get()
clipboard.set_text(tx)
clipboard.store()
output1 = output2
Additional information
command | tee /path/to/terminal_log.txt
Will not copy stderr to the clipboard. To copy both stdout and stderr to the clipboard, use:
command > >(tee /path/to/terminal_log.txt) 2> >(tee /path/to/terminal_log.txt >&2)
as explained here
