173
Say I want to list the contents of a folder and directly paste them into a chat window for a friend to see.
I realize I could do ls > filename.txt to create a file (filename.txt) with those contents; I'd then have to open or print the file and manually select and copy the text block (which can be annoying/tedious.) I clearly could also select and copy the output of ls directly from within the terminal window.
It would be much faster/easier to simply pipe standard output to the clipboard.
What terminal command allows me to do this?
Insperatus
  • 5,093
5 Answers5
205
This can be done with either xsel or xclip command line utilities. Since neither program comes with Ubuntu by default you'll need to first install them via Ubuntu Software or the terminal. Here's how to install them using the terminal (but remember you only need one of these two):
sudo apt install xsel
sudo apt install xclip
Note: If you're using Ubuntu in Windows Subsystem for Linux (WSL) see this Snap Shot's answer instead.
Now some examples. If you want to copy the output of ls to the clipboard here's what you'd do:
  • With xsel:
    ls | xsel -ib
  • With xclip:
    ls | xclip -sel clip
This can of course be utilized for other terminal commands as well. Let's say you want to paste your network info into a help forum.
  • With xsel:
    sudo lshw -C network | xsel -ib
  • With xclip:
    sudo lshw -C network | xclip -sel clip
Make this even easier with a new bash alias!
Edit your ~/.bash_aliases file (if it doesn't exist yet create it first with touch ~/.bash_aliases).
Then add one (depending on which program you decided to go with) of the following:
alias copy='xclip -sel clip'
or
alias copy='xsel -ib'
Then save and close.
Now (after restarting your terminal) you can send standard output to the clipboard just by piping it to copy (or whatever you decide to name your new alias).
For example:
ls | copy
Insperatus
  • 5,093
23
If you are attempting to copy to the clipboard using Ubuntu in Windows Subsystem for Linux (WSL) xsel or xclip will not work unless you are using X Windows as clipboard is only for graphical. However, to pipe terminal standard output to the clipboard in WSL Ubuntu you can use clip.exe. You can then paste into the WSL Ubuntu terminal with standard paste commands and the copied text will be available in Windows as well. For example,
pwd | clip.exe
will copy the current working directory to the (Windows) clipboard.
This search result appears at the top when looking for ways to copy/paste text in WSL so I think it is worthwhile to mention this so readers do not needlessly install xsel or xclip in Ubuntu and instead use clip.exe.
Snap Shot
  • 571
For more recent Ubuntu versions with Wayland wl-copy will do. To install it, run:
sudo apt install wl-clipboard
Example of usage:
ls | wl-copy
If you're using zsh with Oh My Zsh, you can use the clipcopy command to pipe the stdout output to the clipboard, as shown in the following examples:
pwd | clipcopy
ifconfig | clipcopy
echo $PATH | clipcopy
neofetch | clipcopy
You don't need to pass any other parameters, the output is copied directly to the clipboard.
Note: You can also use the clippaste command to view what's currently inside the clipboard.
Copying the path of a file in command line, without any new line after paste:
realpath filename | xclip -r -selection c
The -r switch is necessary to avoid the new line generated after pasting.
