29
I'm wondering if it possible to copy to clipboard output of pwd command.
I often need to copy some path and I have to select it with mouse, do several clicks and that is annoying for me.
What I want is piping output of pwd command to something that will copy it to clipboard so I do not have to touch my mouse
Edit: it will be great if it is possible with some built-in
You can use a program called xclip. For installing it type:
sudo apt-get install xclip
and then do
pwd | xclip -- which copies output of pwd to xclip
Now to get the output type:
xclip -o
or to copy to the "standard" clipboard (to avoid having to use xclip -o)
pwd | xclip -selection clipboard
for more options use
man xclip
bolzano
  • 1,610
11
You can use xclip or xsel, to install xsel just do:
sudo apt-get install xsel
and then do
pwd | xsel -b
to copy the output of pwd to the clipboard.
To get the content of the clipboard you can use:
xsel -b
Here you can read a review of xclip and xsel:
http://trembits.blogspot.com/2009/09/clipboard-from-command-line-xclip.html
Josue Abarca
  • 236
