My ubuntu desktop broke down, after I forced a poweroff after it unexpectedly stuck with no responding. With certain reasons ubuntu desktop may not be stable, since it died twice similarly with a working webpage and an idle terminal.
And now I cannot start GUI. It was blank. I can hear the sound of login page, but nothing shows up. The only thing I can do is entering console mode with alt+ctrl+f1, or boot with a live CD.
  1. I cannot access internet with terminal mode. But files were not jumbled, thus the less files I touch the better.
  2. And I didn't set up a rescue mode (is it a good idea? How do you suggest?).
  3. live CD doesn't directly provide a system completeness check & correction option.
What should I do to restore my system?
Similar question: http://ubuntuforums.org/showthread.php?t=972693 but when I inserted the disc, ubuntu cannot detect it (thus the CD is only bootable). I tried:
sudo lshw -short # list mont points
sudo apt-cdrom -d /dev/cdrom add # mount cdrom
but failed to mount.
knh190
  • 301
1) In Terminal mode can you not even ping www.google.com? or do you just mean you don't have a web browser?
3) You may want to look into the disk checker man fsck
If you can ping google you can check out the answer in this thread for a great detailed explanation of how to create a bootable USB you can install Ubuntu to (and then from). I find this to be the easiest way to install Linux.
With the live CD you should be able to boot up a working version of Ubuntu where you could do this through the GUI, just make sure you select your cd drive in your boot options (Mine is F12) on system startup.
Keeping regular backups is always great practice too (especially before planning to make any system changes)
0x01
  • 16
  1. "Try Ubuntu" with live CD
  2. reinstalled desktop, didn't fix
  3. changed own of /home, and reinstalled suspicious nvidia driver by
    sudo chown -R $USR:$USR /home/$USR  # $USR is your username
    sudo apt-get update && sudo apt-get purge nvidia-* && sudo apt-get install nvidia-current
And everything's back to life.
The most suspicious reason was that you accidently changed own of /home to root. And so everything's loaded but cannot work (locked up). So you revert it back.
CAUTION: unity didn't work after I restored my system. And you need to specify your drivers. see my post: Ubuntu 14.04 - mouse can click, but cannot move
knh190
  • 301
