I have Ubuntu 14.04 everything has been fine. I was using terminal for little low level things and I closed terminal but it wouldn't open back up. I decided to restart but when trying to restart, unity wouldn't boot at all. I couldn't find this same issue anywhere.
I really don't know what to do in this case...
I took two videos of what happens when I boot normally (it hangs after splash) then a video where I can get to tty from recovery mode.
Here is the video when I boot normally.Trying to boot normally: https://youtu.be/ykWUgxhH3S4
Here is the video when I'm able to get to tty with a persistent error whenever I type a command.Trying to boot from recovery mode.: https://youtu.be/zJ1BnVnvk4w
Here is the boot log from boot-repair
http://paste.ubuntu.com/10628382/
Thank you for all the help!
Please explain what you did with your system, and well describe your problem since this quite probably does no matter with boot loader thus cannot be repaired via boot repair.
My suspicion here is you have to reinstall ubuntu-desktop and unity, and perhaps need to change ownership of home directory in case it's accidently locked by privileged user. While with little useful information I can't decide. Read this post if useful: Ubuntu 14.04 - How can I reinstall ubuntu desktop with a live CD?
If this couldn't fix your problem, provide additional information to well describe your problem. I'll try if I can help (cannot make any comment yet).
knh190
  • 301
