15
I'm getting the following error message when attempting to install libglew-dev,
Reading package lists... Done
Building dependency tree
 libcheese-gtk23 : Depends: libclutter-gtk-1.0-0 (>= 0.91.8) but it is not going to be installed
                   Depends: libcogl15 (>= 1.15.8) but it is not going to be installed
 libcheese7 : Depends: libclutter-gst-2.0-0 (>= 0.10.0) but it is not going to be installed
              Depends: gstreamer1.0-clutter but it is not going to be installed
 libclutter-1.0-0 : Depends: libcogl-pango15 (>= 1.15.8) but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
All those packages are however apparently already installed.
I have tried all possible solutions in this post, without any luck. I have not added any PPAs. The version of ubuntu is 14.04.2.
I have looked at similar posts, and tried the following:
Running
dpkg --get-selections | grep hold
prints nothing.
sudo apt-get -oDebug::pkgProblemResolver=true install -f
Gives me nothing of interest, 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Martin
  • 151
I tried to install libglew-dev and I had the same problem. I had to include the following packages to install it
sudo apt-get install  libglew-dev libcheese7 libcheese-gtk23 libclutter-gst-2.0-0 libcogl15 libclutter-gtk-1.0-0 libclutter-1.0-0  xserver-xorg-input-all
It will include then all the required packages.
Harris
  • 2,588
Note: most issues with dev package install has been resolved with mesa 10.1.3-0ubuntu0.4
Packages are currently available in trusty -proposed
Referring bug - https://bugs.launchpad.net/ubuntu/+source/mesa/+bug/1424466
doug
  • 17,212
I had the same problem in Ubuntu 14.04.2 trying to install qtcreator. Also trying to install Qt4/5 development packages such as qt4-default and qt5-default would have downgraded the whole X.org to the original trusty version instead of lts-utopic.
This dependency mess is somehow connected to the new Mesa packages, and can be fixed by manually installing lts-utopic versions. I installed these packages:
sudo apt-get install xserver-xorg-dev-lts-utopic mesa-common-dev-lts-utopic libgles2-mesa-dev-lts-utopic libgles1-mesa-dev-lts-utopic libgl1-mesa-dev-lts-utopic libegl1-mesa-dev-lts-utopic
Niko M.
  • 31
You can use Synaptic for installing libglew-dev package. There you can see all dependencies too and by marking needed dependencies for installing then click on Apply button would install your needed package.
Huseyin
  • 802
