I issued the command string found at https://wiki.ubuntu.com/Kernel/LTSEnablementStack and got this result:
Reading package lists... Done
Building dependency tree
 account-plugin-facebook : Depends: libaccount-plugin-generic-oauth but it is not going to be installed or
                                    ubuntu-system-settings-online-accounts but it is not going to be installed
 account-plugin-google : Depends: libaccount-plugin-google but it is not going to be installed or
 libcheese-gtk23 : Depends: libcheese7 (>= 3.4.0) but it is not going to be installed
                   Depends: libclutter-1.0-0 (>= 1.13.2) but it is not going to be installed
                   Depends: libclutter-gtk-1.0-0 (>= 0.91.8) but it is not going to be installed
                   Depends: libcogl15 (>= 1.15.8) but it is not going to be installed
 libqt5gui5 : Depends: libgbm1 (>= 8.1~0) but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
Charles Green
  • 21,859
If this issue comes up then you will have to uninstall those packages using either the Ubuntu Software center or apt-get.
To use the Ubuntu Software Center: Click on the icon on the Taskbar or use the Super key and type Ubuntu Software Navigate to the Installed packages and find the search bar and for each of those error giving packages type those in and uninstall them.
To use a Terminal(apt-get)
sudo apt-get autoremove packages | apt-get autoclean
sudo apt-get purge
sudo apt-get update
This ensure nothing is left behind.
Also wait for a Mesa update from the Software Center Updater. Then remove libqt5gui5
The packages needed to be removed are as follows
libqt5gui5
At this point use the command given from the wiki and install will occur.
Note: If there additional packages install involving this issue then use the apt-get command using the name of those packages specifically.
Virusboy
  • 1,566
You can, probably, fix this issue by using "aptitude" " instead of "apt-get".
aptitude will gives you several solutions, and all you have to do is to choose the one that matches your needs.
I just had the "same" error when trying to install "qt4-dev-tools" through:
apt-get install qt4-dev-tools
and I solved the problem simply by replacing "apt-get" with "aptitude", then I have chosen one of the proposed solutions.
Best regards,
YounLee
  • 81
-1
You can fix dependencies issues by executing following commands.
sudo apt-get autoremove && sudo apt-get autoclean
sudo apt-get update
Enable stacks by installing Kernel
sudo apt-get install --install-recommends linux-generic-lts-utopic xserver-xorg-lts-utopic libgl1-mesa-glx-lts-utopic libegl1-mesa-drivers-lts-utopic
Fix dependency issue.
sudo apt-get install -f
KK Patel
  • 19,753
-1
You need to install xserver-xorg
sudo apt-get install xserver-xorg
Probably it will give error for gnome-control center.
You need to remove this using
sudo apt-get remove gnome-control-center
Once this is over then re-try
It will be now okay...
Mudit Kapil
  • 2,081
Techgs
