34
I tried to install Synaptic Package Manager but I get the following error message:
Package dependencies cannot be resolved.
This error could be caused by required additional software packages which are missing or not installable.
Furthermore there could be a conflict between software packages which are not allowed to be installed at the same time.
Charo
  • 3,681
siraj
  • 5,407
On the terminal type in the following commands (one line at a time) >>
sudo apt-get update
sudo apt-get install synaptic
Just go here and install offline way if this helps. Synaptic packages for 12.04
Ashu
  • 9,642
ashutosh
  • 1,302
If this is happening then you either have a package version that is lower than the required dependency version or one of your packages is broken.
You can try fixing the packages by running your update manager and checking for updates and installing them.
guntbert
  • 13,475
Ashu
  • 9,642
