19
There are many logs in /var/log/ For a standard home installation, which ones should I be checking regularly?
Marco Ceppi
  • 48,827
Each log serves it's own purpose. It really depends on what you're trying to check for. Some common ones are outlined below:
  • /var/log/auth.log - Information pertaining to authentication - including sudo/su activity
  • /var/log/boot.log - All information during the booting process
  • /var/log/crond.log - Information from cron daemon
  • /var/log/messages - Typical dumping point for messages not regarding the system
  • /var/log/pm-suspend.log - Logged during the Power management suspend function
  • /var/log/user.log - Information from all userlevels
  • /var/log/syslog - This organizes output from different softwares and is a "general log"
  • /var/log/kern.log - Information being logged from the kernel
There are additional logs - like the apache2 folder, mysql.log/mysql.err, and others. These are all software specific - if you don't have apache2 installed, you won't have the log files for it. The only time you would want to check logs is when an issue arises - most of the time though it'll be okay to let them sit in the dark.
Marco Ceppi
  • 48,827
14
I would argue that for a standard home installation, there is no need for you to be checking any logs regularly. Though they may be helpful in diagnosing a problem or filing a bug report.
Also, you can just use the command "dmesg" to see the kernel messages (same as /var/log/kern.log) This usually tells me quickly what is (if anything) going wrong with the system
A trick that I find useful is:
touch /tmp/now
<...make the problem happen...>
sudo find /var/log -type f -newer /tmp/now | xargs sudo less
That shows me every file in and under /var/log that has had something written to it since the touch /tmp/now command.
waltinator
  • 37,856
