The system gives me the following error:
The volume "Filesystem Root" has only 713.9 MB disk space remaining. You can free up disk space by removing unused programs or files, or moving files to another disk or partition.
My question is, which files and from where should I move? How to not get the error any more?
I purged an old kernel [3.13.0.45] some time back and now have two kernels [3.17 & 3.8]. I had to purge 3.13 because incidentally, the free space in the error as shown above had become 0 bytes and the shutting down process too could not happen properly.
Results of df -Th
Filesystem Type Size Used Avail Use% Mounted on
/dev/sda6 ext4 19G 17G 601M 97% /
none tmpfs 4.0K 0 4.0K 0% /sys/fs/cgroup
udev devtmpfs 1.9G 4.0K 1.9G 1% /dev
tmpfs tmpfs 386M 1.2M 385M 1% /run
none tmpfs 5.0M 0 5.0M 0% /run/lock
none tmpfs 1.9G 188K 1.9G 1% /run/shm
none tmpfs 100M 76K 100M 1% /run/user
/dev/sda5 ext4 453M 193M 233M 46% /boot
/dev/sda7 ext4 92G 788M 87G 1% /home
Here is the disk Analysis:
12.7GiB /usr
2.7GiB /lib
1.2GiB /var
877.9MiB /home
190.4MiB /boot
12.4MiB /etc
11.9MiB /sbin
9.6MiB /bin
1.3MiB /run
324.0KiB /root
20.0KiB /tmp
16.0KiB /lost+found
12.0KiB /media
4.0KiB /dev
4.0KiB /lib64
4.0KiB /srv
4.0KiB /opt
4.0KiB /mnt
4.0KiB /cdrom
0.0 B /proc
0.0 B /sys
0.0 B initrd.img.old
0.0 B vmlinuz.old
In usr/:
10.1GiB /src
1.4GiB /lib
1.0GiB /share
100.6MiB /bin
14.4MiB /sbin
9.6MiB /include
520.0KiB /games
112.0KiB /local
In src/:
9.9GiB /linux-3.17.6
94.1MiB /linux-headers-3.13.0-45
90.4MiB /linux-headers-3.8.0-29
13.8MiB /linux-headers-3.13.0-45-generic
12.1MiB /linux-headers-3.8.0-29-generic
Please help.
