I recently received notification that my "Filesystem Root" was running out of remaining space. I followed along this thread. After cleaning up a few folders, this is the output of df -h
Filesystem Size Used Avail Use% Mounted on
udev 3.9G 0 3.9G 0% /dev
tmpfs 789M 2.1M 787M 1% /run
/dev/sda3 28G 25G 1.9G 93% /
tmpfs 3.9G 26M 3.9G 1% /dev/shm
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 3.9G 0 3.9G 0% /sys/fs/cgroup
/dev/loop3 5.0M 5.0M 0 100% /snap/canonical-livepatch/41
/dev/loop2 87M 87M 0 100% /snap/core/4830
/dev/loop0 5.0M 5.0M 0 100% /snap/canonical-livepatch/39
/dev/loop1 87M 87M 0 100% /snap/core/4650
/dev/sda4 200G 9.6G 180G 6% /mnt/b0267352-7943-4965-bbfc-c0728cd84462
/dev/sda1 234M 16M 218M 7% /boot/efi
tmpfs 789M 20K 789M 1% /run/user/124
tmpfs 789M 88K 789M 1% /run/user/1000
/dev/loop5 87M 87M 0 100% /snap/core/4917
After running sudo baobab /, I noticed that most of my local files are stored under /home/username, including Downloads, Documents, Pictures, etc. Is this normal, and if not, how can I set /dev/sda4 as the default location for local files?
Alternatively, should I allocate all the space from /dev/sda4 into / to make it bigger? For context, this is all on a single 256G SSD.
