I can't install this package, it gives me an error, this is the output from terminal:
➜  ~  sudo apt-get install mesa-common-dev
Reading package lists... Done
Building dependency tree
mesa-common-dev : Depends: libdrm-dev (>= 2.4.52) but it is not going to be installed
I have tried apt-get -f install but nothing happend. Please Help, I need this for creating OpenGL apps
PlugaruT
  • 789
what tells you apt-cache policy libdrm-dev?
You must look these posts:
I guess you have some conflicting package repositories/ppa. Or you have to built it manually, but only if you are sure you need a package version not provided by public repositories)
Always look at: How do I resolve unmet dependencies after adding a PPA? Or try to install other version of the conflicting packages: How to install specific Ubuntu packages, with exact version?
