I am trying to install mesa-common-dev (sudo apt-get install mesa-common-dev), however I get the following message:
mesa-common-dev: Depends: libdrm-dev(>= 2.4.52) but will not be installed.
So, when I tried to install libdrm-dev, I get the following output:
libdrm-dev: Depends: libdrm2 (= 2.4.52-1) but 2.4.56-1~ubuntu1 will be installed.
        Depends: libdrm-intel1 (= 2.4.52-1) but 2.4.56-1~ubuntu1 will be installed.
        Depends: libdrm-radeon1 (= 2.4.52-1) but 2.4.56-1~ubuntu1 will be installed.
        Depends: libdrm-nouveau2 (= 2.4.52-1) but 2.4.56-1~ubuntu1 will be installed.
So, I think that this means that alternative packages are installed? However, when I again try to install mesa-common-dev, I get the same error as above...
Can anyone help out a newbie at Ubuntu 14.04? Thanks!
muru
  • 207,228
Look at this line:
It says the libdrm-dev to be installed is 2.4.52-1 and requires its dependencies all versioned in 2.4.52-1. But your apt-get only has 2.4.56-1~ubuntu1 available.
Thus, you may try to 'upgrade' the version of libdrm-dev, that is version 2.4.56-1~ubuntu1, as same as its newer dependencies in your case. Now if you google again with keywords libdrm-dev 2.4.56-1~ubuntu1, and within a few clicks, the download link may pop up and wget it like so:
wget http://launchpadlibrarian.net/192227986/libdrm-dev_2.4.56-1~ubuntu1_amd64.deb
Then, make sure the dependencies are installed:
sudo apt-get install libdrm2 libdrm-intel1 libdrm-radeon1 libdrm-nouveau2
Now install the freshly downloaded libdrm-dev:
sudo dpkg -i libdrm-dev_2.4.56-1~ubuntu1_amd64.deb
rm libdrm-dev_2.4.56-1~ubuntu1_amd64.deb
Hope everything goes smoothly!
drewfle
I encountered this issue when attempting to install the Mutate launcher on Ubuntu 15.04. The solution that worked for me was to add the xorg-edgers PPA:
sudo add-apt-repository ppa:xorg-edgers/ppa
sudo apt-get update
sudo apt-get install <whatever you were trying to install>
I found that by adding this PPA, these dependencies became resolvable when I tried to install the launcher.
msolters
  • 353
