After a recent update my Gwibber installation is almost totally useless. I'm wondering what the process is to totally uninstall my system of Gwibber and all its' files and start over with a completely new installation. The version I'm having problems with is 3.1.5 and would like to downgrade to the last stable version. Thanks in advance!
Jorge Castro
  • 73,717
tclick
  • 339
Assuming you have installed the gwibber-daily ppa from launchpad you would copy and paste the following into a terminal:
sudo ppa-purge ppa:gwibber-daily/ppa
This will revert you back to the default v3 natty install of Gwibber.
fossfreedom
  • 174,526
As fossfreedom pointed out, you need to purge the PPA. You can avoid doing that if you know how to downgrade packages using Synaptic, or if you want to reinstall gwibber.
To do the reinstall method (which will potentially remove a few other packages that you can easily reinstall), open synaptic, disable the Gwibber-daily ppa (I'm guessing you used that one), reload your sources, remove all gwibber-*, *gwibber and gwibber* packages, and install gwibber and the related packages again.
RolandiXor
  • 51,797
