I recently installed Kubuntu 14.04 and I installed available updates. Then, I got a black screen with mouse pointer visible. I lost my desktop. However I got to terminal with Ctrl+Alt+F1. Then I ran sudo apt-get install kubuntu-desktop. It gave me my desktop back.
Unfortunately, I found that some applications were broken and missing such as muon, dolphin, kontact, ktp-contactlist, etc. I tried several tips about package and apt commands. Nothing worked. sudo apt-get update and sudo apt-get upgrade did not solve the problem. Nothing was upgraded.
I could successfully installed dolphin by running sudo apt-get install dolphin. But I failed with muon and kontact. The below is what I tried for muon.
sithu@sithu-kubuntu:~$ sudo apt-get install muon
Reading package lists... Done
Building dependency tree
muon : Depends: libmuonprivate2 (= 2.2.0-0ubuntu3) but it is not going to be installed
Recommends: muon-updater but it is not going to be installed
I tried to install libmuonprivate2, but it depends on software-properties-kde.
sithu@sithu-kubuntu:~$ sudo apt-get install libmuonprivate2
libmuonprivate2 : Depends: software-properties-kde but it is not going to be installed
I tried to install software-properties-kde, but it depends on python3-software-properties.
sithu@sithu-kubuntu:~$ sudo apt-get install software-properties-kde
software-properties-kde : Depends: python3-software-properties (= 0.92.36) but 0.92.37.1 is to be installed
I tried to install python3-software-properties, but it seems update-to-date.
sithu@sithu-kubuntu:~$ sudo apt-get install python3-software-properties
python3-software-properties is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
I also tried to locate and re-install broken packages using Synaptic Package Manager, but no luck. Applying the changes gave me this dialog:
Could not apply changes!
Fix broken packages first.
"Fix broken packages" gave me this dialog:
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
E: Unable to correct dependencies
Any help would be highly appreciated.
