I have just installed Ubuntu 14.04 and I am not able to connect through wi-fi.
I have tried out this wifi not working asus x550cc it is hard blocked
my asus_nb_wmi is loaded and
rfkill list all
Show this
2: asus-wlan: Wireless LAN
Soft blocked: no
Hard blocked: no
3: asus-bluetooth: Bluetooth
    Soft blocked: no
    Hard blocked: no
edit : I tried this too but in vain
sudo modprobe -r asus_nb_wmi
sudo modprobe asus_nb_wmi wapf=1
sudo rfkill unblock all
Sinscary
  • 1,415
Yours should work with echo "options asus_nb_wmi wapf=4" | sudo tee /etc/modprobe.d/asus_nm_wmi.conf Then you should be able to reboot and use your keyboard to enable wifi if it is still blocked
This should be fixed eventually as the code is in the asus_nb_wmi module in linux-next
.callback = dmi_matched,
    .ident = "ASUSTeK COMPUTER INC. X550CC",
    .matches = {
        DMI_MATCH(DMI_SYS_VENDOR, "ASUSTeK COMPUTER INC."),
        DMI_MATCH(DMI_PRODUCT_NAME, "X550CC"),
    .driver_data = &quirk_asus_wapf4,
Jeremy31
  • 13,293
After a lot of surfing finally i found a solution.
I found this driver built by Md Jahidul Hamid on github.
First of all download and extract the files.
Than give it execution permission by running
chmod +x install test uninstall
Now to install it run
./install
To test it without installing, run
./test
To uninstall, run
./uninstall
To install with dkms run
sudo make dkms
Hope this helps and a lot of thanks to all those who build this driver.
for more info visit this blog
Sinscary
  • 1,415
