hello all i have Asus x550cc laptop with ath9k wifi card in which I have a problem with Ubuntu 14.04. i can not enable wifi it shows wifi is disabled by WiFi switch I tries 'rfkill list all' command it shows wireless Lan hard blocked yes. I have no physical button in my comp for wifi all I know is alt+F2 for enabling disabling wifi pls help.
subodh007
  • 350
Is the module asus_nb_wmi loaded? Check:
lsmod | grep asus
If so, try a temporary fix:
sudo modprobe -r asus_nb_wmi
sudo modprobe asus_nb_wmi wapf=1
sudo rfkill unblock all
rfkill list all
Any improvement? If so, make the driver parameter permanent:
sudo -i
echo "options asus_nb_wmi wapf=1" | sudo tee /etc/modprobe.d/asus_nb_wmi.conf
exit
If the parameter 1 is ineffective, we can also try 0 and 4.
chili555
  • 61,330
To turn Wireless ON when your systeem starts up do the following:
Open a Terminal (CTRL+ALT+T).
Enter the following line only if you don't have gksu installed.
sudo apt-get install gksu -y
If you have GKSU (installed or already have) enter the following:
gksudo gedit /etc/rc.local
The rc.local fill will open up, add the following line before the exit 0:
rfkill unblock wireless
Now enter the following line in a terminal:
sudo reboot
To turn Bluetooth OFF when your systeem starts up do the following:
rfkill block wireless
sudo reboot
To switch between ON or OFF you can use the FN+Wireless key on your keyboard. This key is different for each system. You can change wireless also for something else, like bluetooth.
Korkel
  • 1,168
I have installed Linux Mint on my Asus X550C and I have found a way to enable wireless! I will write what I've done:
Terminal:
lspci -nnk | grep -A2 0280
Bash answer: ...
Kernel driver in use: ath9k
lsmod | grep -e ath9k -e asus
Bash answer: ... ... asus_nb_wmi ...
Check if you find asus_nb_wmi in the output!
rfkill list all
See if "Hard blocked: yes".
Suspend the notebook by pressing Fn+F1 then resume it again and wireless will be enabled!
guntbert
  • 13,475
Luca
