80
I would like to know how to upgrade from my current version of Ubuntu to the next stable from the Command line interface?
Braiam
  • 69,112
myusuf3
  • 35,659
You'll first need to make sure update-manager-core is present (it may already be installed):
sudo apt-get install update-manager-core
Next, run:
sudo do-release-upgrade
You may need to check /etc/update-manager/release-upgrades and change the line:
Prompt=lts
to:
Prompt=normal
for the release to show up.
Jorge Castro
  • 73,717
Meta Bergman
  • 2,271
13
If you run the command sudo do-release-upgrade -d through SSH then use a GNU Screen, because the upgrade process will turn off SSH -> close the default port and open a new one (it will inform you of this new port), so:
$ ssh USER@HOST
$ screen -S upgrade
$ sudo do-release-upgrade -d
open a new terminal on client computer:
$ ssh -p PORT USER@HOST
$ screen -d
$ screen -r upgrade
techraf
  • 3,316
PetterA
  • 131
You can do
for command line updating
(This is actually the same as for Ubuntu Server)
Peter Smit
  • 7,707
