I would like to upgrade my Ubuntu 11.04 from the command line (this is a remote machine I can only SSH into). I am following these directions. I am getting 404's from many commands I am trying to run such as:
sudo apt-get install update-manager-coresudo apt-get updatesudo apt-get install libkrb5-dev
What can I do to apt-get install these things without 404s from the command line? I can only use the command line.
Here is an example of the 404.
$ sudo apt-get install update-manager-core
[sudo] password for melissa:
Reading package lists... Done
Building dependency tree
The following NEW packages will be installed:
update-manager-core
0 upgraded, 1 newly installed, 0 to remove and 95 not upgraded.
Need to get 165 kB of archives.
After this operation, 1,294 kB of additional disk space will be used.
WARNING: The following packages cannot be authenticated!
update-manager-core
Install these packages without verification [y/N]? y
Err http://archive.ubuntu.com/ubuntu/ natty-updates/main update-manager-core amd64 1:0.150.5.4
404 Not Found [IP: 91.189.91.13 80]
Err http://security.ubuntu.com/ubuntu/ natty-security/main update-manager-core amd64 1:0.150.5.4
404 Not Found [IP: 91.189.91.14 80]
Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/u/update-manager/update-manager-core_0.150.5.4_amd64.deb 404 Not Found [IP: 91.189.91.14 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
